Diagram of fuse panel
Where can I get a diagram of a Corvette fuse panel for a '77 (or similiar if they didn't change from nearby years, which I doubt it did too much if at all) that shows what each fuse is and what is on that circuit? Just trying to figure out why my interior lights don't turn on, I know one fuse is out (left side, bottommost) but I can't read it and is too short for my fuse puller and I'm kinda lazy right now. :D
Re: Diagram of fuse panel (Schmucker)
The fuse for the interior light is the shortest of all fuses at the very bottom (5A).
If it is not blown, a bad headlight-switch (coil of the interior light dimmer is broken) might be the culprit.
With a small screwdriver and good feel in your fingers, you can also pry them out (apply srewdriver as close to the end of the fuse as possible).
Good luck.
Good luck.
Re: Diagram of fuse panel (V8yunkie)
Heh, well, it is blown, hopefully just a blown fuse then and not a short, will find out when I change it.
