rebuilt top end - compression too much for battery
I'd start with a fresh battery. Mine was behaving the same; hard to turn over after driving even a short distance. Now, even after driving, it spins right over.
Ordered new cables from http://custombatterycables.com/. That is what finally fixed my problem. Here is my current set up.
1000 cranking amp, top post battery.
1/0 ga ground to frame with blade type disconnect
1/0 ga ga Positive to starter
PMGR GM starter. (2000 Escalade)
4 ga ground from motor mount to frame
Additional 4 ga braided ground from starter to frame
Spins fine after hour long drive in 101* outside temps.
so i took the car for another spin around the block..im really leaning towards heat now...the headers i have are patriot headers (the true dual kit from corvette central). The pass side header basically touches the "tit" if the starter that sticks out.
I had the same problem.
Everyone was preaching about heat problems...
Basically the wiring gets too hot and it increases the resistance in the starting circuit.
5 options that will help.
New higher amp battery.
*More power to the circuit
-This is a temporary fix. After a year of so the same issues may crop up again.
Heat shielding
*Less heat = always good
- After very long trips this ends up being useless due to heat soak. Great solution for most drivers.
New mini starter
*lower amps required in the circuit.
- Can get pricey. May require shimming. Labor intensive.
New wiring
*lower resistance in the circuit.
- Will fix the issue. VERY labor intensive. Can be expensive.
New high preformance ignition coil. *my choice*
*More power.
- Relatively cheap and easy to install.
I got stuck in the parking lot at work for 2 hours in 95+ heat. Single click and then nothing, it would kill all the electrical in the car. I finally got a friend with a large truck to jump me. His battery had enough spare amps to get my girl started but we ended up popping a fusible link.
I replaced the ignition coil and havent had an issue since.
The battery was new and the original ignition coil worked fine in a different vehicle.
Heat shielding
New mini starter
New wiring
*More power.
Heat shielding
New mini starter
New wiring
*More power.
Heat shielding
New mini starter
New wiring
*More power.
I have an MSD coil in my HEI dizzy
Also when it's cold...takes 3 or 4 cranks before she will fire off ...that indicate the starter as well over heat or battery ?
So I ran the car in the driveway for 10 min last night. Shut it off..waited 2 min..tried to start - it was like a dead battery...barely even turning over a full rotation.
** I haven't changed anything yet - been locked up at office - cant even get lunch (ughhh) let along get to parts store
My father-in-law was over and witnessed it in person...he pinged me later in the evening with a thread he found on Heat soak for starters that have close fits aftermarket headers (what I have)....I checked all wires...in great shape, connected firmly and no corrosion....
so I guess I have a heat soak issue on my starter as most have indicated on here.
Where do I find a "mini starter" and a heat shield for it? And whats it gonna cost me ? LOL
My luck when I take it to gas station I'll be stuck there until it cools off...I'm not about to deal with that...
My buddy has a lift and I'm taking it next weekend to his place so we can do the bushings, springs, and shocks...since it will be on the lift...its the best time to replace the starter....
Starter solenoid is kuput. Starter itself is likely fine. Just replace the solenoid and check results.
Crazy as this sounds...Autozone is double the price over Ecklers...! It must be getting ready to snow in FL...lol
the Link you provided for the mini starter - 70 bucks - I'm just about sold at that price and its a lifetime warranty as well...rather compelling. Do you run this one? Others on here run it, like it?
*** Autozone price for the starter sol is 42 bucks - thats 3/4th the cost of the mini starter....
#34
Do you have an O'Reilly auto near you? 20 bucks...
http://www.oreillyauto.com/site/c/de...1931&ppt=C0330
As far as the Skip White one, I personally have not run one, but I was planning to. You just need to make sure your block is drilled for the straight across pattern. They had a bad rep for a long time, but my understanding is they have resolved a lot of those issues. The other option is to find a GM Ministarter from a later model truck (if you wanted to go junk yarding). Swapped the direct drive starter to a gear reduction one on my 1996 2500 and it made a huge difference in starting the motor (and I didn't have starting problems to begin with)
#35
#36
My stock L36 ate a parts house rebuilt starter every year or so. I got a Summit min-starter 10 years ago and never looked back.
It's kinda weird, they worked from the factory but there seem to have problems nowadays.
Mini-starters rock. She spins like the plugs are out.
#38
Also I found this great writeup that uses the Mini starter and a heat blanket....mayb e I should just do both? I called and chatted with White perf this AM on their mini starter to get familiar with it..all good information, and he recommended a heat blanket as well from Summit or Jegs, etc.
http://www.rodandcustommagazine.com/.../photo_07.html
the heat blanket used in this article is here:
http://www.summitracing.com/parts/the-14150/overview/
#39
go with a mini starter that shield alone is about half what i paid for my starter. once you have one you will see the difference.
