Question on radiator mount change
I have a 72 Vette that originally had a 27 inch radiator mounting and a big block. I want to install a 26 inch radiator support bracket and use a small block aluminum radiator. Will the 26 inch radiator mount bolt right in to the 27 inch location? Will the bolt holes line up or will I have to drill new ones (no big deal, just would like to know).
Thanks,
Dep
Thanks,
Dep
Received 2,878 Likes
Hi Dep,
Besides the question of the top mount, have you taken into account that the core support for the copper radiator doesn't have the 2 lower brackets to receive the 2 'pegs' on the bottom of the sb aluminum radiator.
Or maybe you're using some other aluminum radiator or core support?
Regards,
Alan
Regards,
Alan
Hi Dep,
Regards,
Alan
Regards,
Alan
All that stuff is available and can be installed fairly easily. I just want to know if the surrounding 26 inch gizmo will mount fairly easily. The 27 inch radiator and surround is GONE and I sure don't want it back again. I'm not looking for some kind of concourse restoration. The car is already gutted for the strip.
My company made the metal Corvette radiator supports from 1960-1982. Your support has two lower brackets, that are spot welded the correct distance for the 27" core. Between the two brackets is an "L" shaped metal piece, that is also spot welded. The 26" radiator has the right hand lower bracket moved to the left, one inch, along with an inch shorter "L" shaped bottom piece, between the two lower brackets.
The upper support holes, I think, are in the same location. The two upper radiator brackets are different, to accommodate the two different radiator widths. Dewitt's makes aluminum radiators to fit both sizes. I do not think that it is worth all of the trouble to modify the lower right support bracket, to put in the 26" radiator. One inch of aluminum doesn't weigh that much more. Hope this helps you out. Lou.
If I have to buy a new radiator support bracket, no problem. This is the gizmo I am talking about. Not upper or lower, but complete surround. I can Mickey Mouse upper and lower brackets. This is a 26 inch surround bracket for an aluminum radiator.
The radiator support shown in your photo is used with the smaller aluminum radiator (small block, 4 speed, no air, non LT1). Radiator has no cap and surge tank is used. Radiator has two pins that sit in the two lower brackets shown in photo.
The 26" radiator support is different. Lower brackets are further apart and radiator sits in different style brackets. This style radiator has it's own cap.
If your intensions are to have a larger radiator with a cap you will need to purchase the following support along with the two upper bolt on brackets and the four rubber pads. Lower brackets are weled on and are included with new support. The support in your photo will not work.
http://www.zip-corvette.com/catalog/...category/6905/
