Removel of ac condensor and compressor (76)
I'am starting to to tear into my radiator replacement job. I'am going with the new aluminum radiator and electric fan like I've seen a few people here go Since I already have my radiator out and I was already going to remove the air cond compressor (more room less motor drive) I started thinking of removing my air cond condensor in front of my radiator Will I get any benefits from this? cooler radiator, more air less weight,?Do I have to remove my hood for this job to reach the hoses on the side the condensor? Any body have any bad sides to this job I really don't care about keeping the car correct but I would still keep the parts for some day down the road somebody might want to put it them back on. Thanks for any advice or opinions on this . Carver (SLO RDE 76 L-48 auto)
Re: Removel of ac condensor and compressor (SLO RDE)
If you have a rad and are taking the compressor out, no need for the condensor. Yes more air flow and less weight.
Four bolts and two lines and it's out.
Terry
Terry
Re: Removel of ac condensor and compressor (trw)
True, no need for the condensor, but I left mine in if for no other reason than to protect the radiator from junk in the road......I run a 160 degree stat and the temp stays right there so air flow is not an issue with me. :D
