Engine Date Code 1977 c3
Old 09-30-2014, 02:58 PM
HavaC3
2nd Gear
HavaC3's Avatar
Default Engine Date Code 1977 c3
I have a 1977 L48 Automatic trans. The books say only engine date code 3970010 was used for 1977 corvettes. I have date code 3970014, and yes the numbers on the front pad match my VIN. It is a CLA with date code 3970014.
Wondering if someone can help me understand the discrepancy and tell me if it is a 2 or 4 bolt engine. Thanks
Old 09-30-2014, 03:10 PM
MelWff
MelWff's Avatar
Received 1,808 Likes on 1,599 Posts
That 6 digit number is not a date code. CLA would be a 2 bolt.
•Also cast into the top rear of the block is a four-symbol code indicating when the engine was built ◦The first letter of the date code shows the month the block was cast
◦The one or two numbers shows the month
◦The last digit shows the year
Old 09-30-2014, 03:13 PM
Revi
Revi's Avatar
3970010 & 3970014 are the casting codes for a Chevy 350 block, but there are others as well. Millions have been made.
You should see some letters/numbers on the engine stamp pad next to the CLA. (example V0127CTJ)
V-Flint, 0127 - Jan. 27th
This is an axample of a 1970.
Old 09-30-2014, 03:50 PM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
Originally Posted by HavaC3
...It is a CLA...
There are numbers and letters in front of the CLA. V for Flint Engine; the remaining four numbers are the month and day the engine was assembled at Flint. The engine assembly date must be before the time build code on your trim tag.
Old 09-30-2014, 11:28 PM
HavaC3
2nd Gear
HavaC3's Avatar
Thanks for all of that info. Excellent information. It looks I have V0825CLA.
My mistake in calling the casting code the date code, but at least I now know the engine assembly date and that CLA is a 2-bolt main engine...how do you know CLA is a 2 bolt?
Again, thanks for the replies and information.
Old 10-01-2014, 08:12 AM
AdamMeh
AdamMeh's Avatar
If I'm not mistaken, the L48 were all 2 bolt mains and the L82 was a 4 bolt main block.
Old 10-01-2014, 11:37 AM
Easy Mike
Easy Mike's Avatar
...It looks I have V0825CLA...
Bingo. An L-48 for automatic transmission assembled on August 25.
To Engine Date Code 1977 c3
Quick Reply: Engine Date Code 1977 c3
