Cold air intake on my LS1 equipped '82=easy!
htown81vette (04-11-2016)
Took advantage of the space between the bulge in the hood and top of the radiator support. The unit seals against the bottom of the hood and is open in front
The CAI is made from aluminum and welded together
Test fitting before painting
Side view of the unit installed
This is on my 68 sb...I'm sure something could be made for the 82 though getting the MAF sensor to fit might be difficult. Check out K&N's website for different filter sizes and shapes
That would be me and here's a few pics of the CAI Paul is referring to
So is this using a stock BB / LT1 style OEM hood?
I'm trying to picture the area that you have that can actually draw air from above the core support?
Seems there is maybe an inch or so space (height) if you remove the foam air dam? Is that enough?
I'm guessing this could be made to work with an OEM style rectangular air filter so you could perhaps put the MAF IN the box?
I'm installing a FIRST TPI intake on my 69' this Winter and am looking for ideas..
Nice work!
This is with the stock small block hood. If you remove the foam, air would be allowed to pass through into the engine bay and this is what I am using for an outside air source. Seems to be plenty of air to supply the motor(running a 383) with no noticeable change in engine temp since this is air that would otherwise flow through the radiator.
I have 15" between the front face of the throttle body to the edge of the rad support, I'm sure a flat filter and MAF could be squeezed in but keep in mind that TPI units set further forward than LT1-style intakes so that 15" may end up being more like 12-13"
Seems like that may give you a little more room to work with than the later cross-flow copper radiator?
I wonder if this concept would work equally as well in that scenario-
Thoughts?
Elm
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
I question if a GTO Vararam over the radiator intake would, or could be made to, work. The only issue I see is the height of our core support and possibly the difference in depth from the radiator to the throttle body. I am half tempted to buy the GTO CAI just to see if it will be close enough to work.
The rad I have is a DeWitt's Direct-fit with a Ford Taurus fan attached....I should also note that the original shroud and fan would not have allowed enough room
This would save people a lot of fab work if it fit
You should be able to get something to work...can you post a pic of the top of the rad?
I don't know that the entire thing would fit anyone's C3 but, looking at your first post photo, I don't see why it is entirely impossible. The Vararam sits right at the edge of the radiator. On my LS swap, with the exception of the Corvette Power Steering reservoir, that is where I have the most room. My LS sits low, so low that you could not go straight out the front of the throttle body and even remotely expect to go over the core support. However, if there were a way to use this filter shield and put it on our radiator, or figure out a way to mount it to the core support, it isn't out of the question that you could make the connection to the throttle body and still have a MAF sensor in between the filter and TB. Even the Vararam instructions state that the filter & enclosure are designed to be mounted at an angle and that the connecting pipe is to be cut at an angle so that it mounts correctly.
Just throwing the idea out there. I imagine if it were that easy, someone would have already done it by now...Although, there is a black C2 or C3 that did nearly this very thing... I'll have to find the pictures. I think it was a CIC car.
AirBusPilot (04-12-2016)
#33
Here's a few tips to help get started:
Decide what material you want to use. I didn't use fiberglass because I hate sanding and considered using ABS at one point, even looked at youtube videos on how to form it in the oven but I decided on 1/8" 5052(the type that can be bent without cracking) aluminum since it was available and I had access to tooling to work it
Build a mock-up out of cardboard first then transfer the pattern to the material the CAI box will be made from
The weatherstripping I bought from McMaster-Carr, there's several different sizes and configurations to pick from
As I mentioned in another post, check out K&N's site, lots of different size filters to choose from
Have any questions just ask, I'll be happy to help....would like to see pix on what you come up with
Illegal Vette (02-23-2019)
#34
Nope, go right ahead my design is actually based on another forum members CAI for his LS motor except his was made from fiberglass and he used a filter similar to the one fleming23 posted
#35
The aluminum 'L' bracket across the top holding the Mark VIII fan would need to be re-configured obviously but space otherwise- Thoughts?
Elm
#36
I would start by measuring the distance between the rad support and the hood. I came up with an area about 15" wide and 1 1/4" at its highest point....your core support appears to be different from mine so you may come up with a different measurement
#37
#38
I did a rough mock-up today, here's a few pics.
It fits under with the hood closed and will take this air filter:
http://www.summitracing.com/parts/knn-33-2081/overview/
The MAF should fit inside the box, I'll order the filter and see if my dimensions are correct.
#39
Interesting! What do you plan on doing with the flat filter or rather, how are you mounting it?
Getting my hopes up on this one....
#40
I'm going to put a flange in so the the filter will go in from the top and sit on the flange. I haven't decided how to hold it down yet, but it shouldn't be too difficult. Another flange to sit on top of the filter perhaps.
