AC/Heater Control Head Question 78-82s
The ac/heater control does not change the air flow from the floor to vent, ac, defrost, and heater. The air blows out at the floor no matter what position the control lever is in. Could this little part be the source of my problem or am I looking for something else that may have broken?
http://www.parts123.com/parts123/yb....5Z50000050G~~~
YES ...this part can be part of your problem...but MAKE SURE that when you disconnect the vacuum harness from it...that you crank the engine and MAKE SURE that you have vacuum at the solid black hose in the vacuum harness connector. NO VACUUM...it will not work. Ad then you have a problem out in the engine compartment where the small hose that goes to the switch you plan on buying is not getting vacuum from the intake via the special 'T' fitting.
Make sure that the check valve at the intake vacuum hose ( silver one with one port on one side and two ports of different sizes on the other is ACTUALLY a check valve and will only allow vacuum to flow one way.
http://www.corvettemods.com/product....700aAiG38P8HAQ
Also the white filter in line with this check valve more than likely need to be replaced due to the filter material is gone and you can look through it.
DUB
DUB
Received 1,468 Likes
Cruise-In II Veteran
Guys, the MOST COMMON PROBLEM that results in this is the tiny little vacuum line came apart right behind the distributor. The vent position will stay floor only if there is no vacuum to the control.
If you worked in the distributor area on plug wires, cap, rotor, it is STUPID easy to have this little line come unhooked. Cheap and easy to go look!
You don't need to remove the dash, jut remove the glove box insert and you'll be able to get to the vent door control and the end of the cable.
DUB
Problem Located
I got to the vacuum selector switch and pulled the vacuum harness off. I was NOT getting vacuum to the selector via the black hose. So back under the hood to investigate.
What I found was a cracked vacuum line located right as it goes into the firewall behind the distributor. It was covered with ribbon strip caulk right where it was broken so I didn't see it the first time.
I got a short piece of vacuum hose and connected the two hoses together. Checked the vacuum harness for vacuum at the black hose. I had vacuum at the hose and all functions worked as they should.
THANKS GO TO DUB! He nailed it.
Now on to the next issue...
JUST a TIP for others. I run into Corvettes where this a hose that comes out of the firewall grommet breaks/splits right at the grommet. When this happens...I drill out the old hose in the grommet CAREFULLY and do my repair on the inside of the car using brass fittings and NOT plastic fittings. Because I only want to get into the dash ONE TIME. AND that is if the owner is concerned about the hose looking original (rubber). IF NOT...I use the hard plastic tubing that the newer Corvettes uses and I have the unions that can make everything work. And if in time the hard plastic line were to break...I can pull it out and easily slide one through the grommet.
DUB
