Valve train geometry problem or something else??
#61
Good info. Could be I have parts that don't play well together.
With correct pushrod length this problem may dissapear or it may not.
The Lunati springs spec'ed for the cam are these;
http://www.summitracing.com/parts/lun-73100-16
The springs on the head now are these, or at least close to these, Summit seems to have the wrong coil diameter listed, as the ones I have are 1.5" outer diameter coils;
http://www.summitracing.com/parts/dr...0111/overview/
So here is what I'm thinking, put in the pushrods (and replace shims while I'm at it) and run it.
If it's not ba-bam! better then give the Lunati springs a try. See if then it's better.
Sound like a decent plan?
http://www.race-mart.com/Lunati-LTI-73100-16.html
#62
I was just going to replace the .015 shims. No plans on changing the installed height. So it will remain 1.8".
Not sure what you mean by it taking out the flat tappet lobes. Roller cam here. Do you mean the cam lobes could be now or later get damaged by the situation should it persist.
Looking at the pushrods, rockers, and roller tips I don't see any evidence of them loosing contact with their mating surfaces, at least not to the point of creating any flat spots or unusual wear. But point taken on potential for damage.
Thanks for the link on the springs. Good price. Suspiciously cheap springs compared to what is installed now.
#63
Edit: Think install height is 1.850 on these. Might need spring cups and or retainers. Nothing is easy!
http://www.lunatipower.com/Tech/Valv...pringTech.aspx
#64
Location: Las Vegas - Just stop perpetuating myths please.
REEL, sorry i know its not funny to u but the rocker tip or its pattern on the vlv tip didnt do that. Ok enough, i dont want to ruin your thread as your efforts sharing this is going to help a lot of us here.
So i took a look at your dyno thread and your dyno sheet only goes to 5200rpm. Up to that speed the curve looks mostly smooth but seemed to die down a little early for your cam.
Also i see your cam lift is 0.549" and spring installed height is 1.80" with 1.251" full open but what is that springs solid height? U really need 0.060" safety margin which would put your solid height needed at 1.191". I bet your not even close to having safe margin.
Only quick fix i can think of (if your springs solid height is > 1.191") is replace your shims (correct the installed height) and install 1.5 ratio rockers. Yea, still an experiment so the fix is really up to you with what u can afford.
Good night everybody.
#65
#66
Your right the rocker tip or it's sweep did not eat out that shim. The spring did. But you got to ask yourself why did the spring do that?
In order to eat up that shim the spring had to be jack hammering the shim. Which means at times it was not in contact with the shim.
In a properly operating hydraulic valve train nothing should loose contact with anything else, unless your lofting valves.
So then why would the spring loose contact with the shim? That's the question. Seat and open pressures are adequate for the application so that's not it.
Spring surge cause by resonance is believed to be the reason. spring surge that violent has to be induced by resonance.
Pushrod length, wall thickness, diameter and rigidity can all change the resonance frequency of the valve train due to how the pushrod "rings" when it pushes the rocker because it flexes. Not only that but any vibrations from the cam shaft, crank shaft, and the block, heck the whole engine, are also transmitted through the pushrod to the rocker to the spring.
Obviously numerous other factors also effect the frequency. But here it assumed the pushrod length could be the answer...for now. It will of course still resonate just hopefully not destructively.
Mako63 is also speculating that it could be the springs and how they resonate with the rest of the engine and valve train.
I'm not stressing over it. It's kinda interesting to me, and a great learning experience. Just like to get it under control, that's all.
#67
.149, IMO, is too much clearance from CB. IF POSSIBLE, given all the factors, I like to run under .100 from CB. As a rule, the closer you can run to CB the more settled the spring will be although some springs seem to run a little better a little further off CB. In this case the rocker is the limiting factor since it will take only so much pressure. I would install this spring where the open pressure was 10-15# below the max recommended of the rocker which is 350#, so I would be shooting for an installed height that, with the spring's measured rate combined with my net lift, would give me somewhere around 335-340 open pressure. The cam will love the added seat pressure and the closer this gets you to CB the better. Since the open pressure is the limiting factor you kinda have to back into the best installed height.
#68
#69
Spring recommended by Lunati for his specific cam has an install height of 1.850, lift is .549, Spring height at max lift is 1.301 Coil bind is 1.110. Difference between max lift height and coil bind is .191 if you use the recommended spring with the recommended install height from the cam manufacturer.
Perfect example of why I like to think these things through instead of just go off a catalog. Quite often I'll have two different springs on a set of heads, one for intake, one for ex. The devil is in the details.
#70
It appears that perhaps the difference in the mass to control or maybe that combined with the temps that they run at is having some effect on the guide wear. So the two valves are not responding/acting the same despite having the same spring and installed height.
#71
Cant see much of the vlv guide from any of your pics REEL but while u have some of the springs off u should measure the distance from the installed vlv retainer (no spring) to the top of the guide with the seal installed also. U need your max lift of 0.549" + 0.060" safety margin for 0.609" clearance under the retainer. Thats all i can think of right now as your not running a huge cam but something is hammering the shim under the spring.
Also checking your rocker clearances is something needed to be done for the full travel of the rocker arm.
Check the rocker arm to retainer clearance (0.40").
Check the rocker slot ends from the underside - 0.060" each end of travel (vlv open and vlv closed).
Thick unbent paper clips work pretty good for this.
Wow coil bind at 1.100" - thats huge from what im used to. But an extra 0.080" more than needed is another topic no one here can say is too much. Though your spings seem to have a short life and are declining fast your dyno chart doesnt reflect bad harmonics. Thats why im think'n somethings not fit up quite right.
Last edited by vettebuyer6369; 10-27-2014 at 11:28 AM. Reason: edited out personal commentary
#72
Good luck! Hope you get it sorted out.
Last edited by vettebuyer6369; 10-27-2014 at 11:28 AM. Reason: edited out personal response
#73
I don't know that we can say with any certainty that the spring life has been shortened to any degree greater than normal.
First I didn't test the springs when they were new so their true pressures then are an unknown. All we have to go on is the advertised specs. So far that, in my experience, has not been a source of reliable information for any new component on this engine.
Second other than the 10% normal loss of pressure from running, who but an engine builder that tears down engines frequently to rebuild them with used components can say what the spring pressure on their valves is after 1500, 5000 or 50,000 miles. Who test that? Normally, not the average Joe.
I'm not confident that a chassis dyno would be a reliable indicator of poor harmonics unless the effect was so pronounced as to create large fluctuations in power. Now the early sign off of the engine power could be an indicator.
Since the power we are looking at is going through the transmission then the rear end and finally to the tires, it seems to me that smaller fluctuations might not be observed due to the dampening effects of the drive train components.
Excessive wear to the valve train certainly illustrates a problem though.
First order of business is to correct the geometry. That's what I plan to do.
If the pushrod is looked as a tuning fork (which it kind of is) then I'll be changing the frequency of the tuning fork by changing the length.
Now while I'm at it I see no harm in increasing the seat pressure which by circumstance will increase the open pressures and run the spring closer to coil bind. Keep open pressure under the limit of the rockers and it should be good to go.
I can't see why, just because a spring has a recommended install height, that is cannot be altered as long as over the nose and seat pressures are acceptable and coil bind clearances are sufficient.
If one way a spring coil dissipates it's energy is to touch another coil or another spring then running the spring closer to coil bind can aid in dissipating the energy of the adjacent coil. This would alter the harmonics. Change the coil surge frequency and perhaps keep it on the seat.
Should that not be enough then further steps can be taken like changing to different springs.
I would like to find the problem and fix just that. I don't wholesale change out a bunch of stuff to fix an issue. I like to fix the specific problem.
If my Q-jet develops an issue I like to fix the issue with the carb not bolt on a new carb.
If I cannot fix the specific issue then maybe try changing things out to resolve the issue. Although I can't remember that I've ever had to do that.
I know much of modern auto mechanics involves changing components until the right one fixes the problem, and that will work, but then you never know the specific cause or solution of the specific problem.
Especially if you changed many things at once. So next time a similar issue comes up you still don't know how to fix it other than changing components until it's resolved. If you got lots of $$ to burn and no interest in the cause that works.
So I'm gonna see how it goes. Like I said little is lost if it doesn't work. But at least I would know what doesn't work. That's a good half way to knowing what does work.
#74
Wow coil bind at 1.100" - thats huge from what im used to. Though your spings seem to have a short life and are declining fast your dyno chart doesnt reflect bad harmonics. Thats why im think'n somethings not fit up quite right.
Last edited by vettebuyer6369; 10-27-2014 at 11:36 AM. Reason: argumentative parts removed
#75
Couple of thoughts here.
#76
Ya know it's always hard to say what is exactly meant by certain comments on a forum.
You can't get the inflection in the voice or the expression on the face or the body language either. So lots of times things are taken wrong and some folks get insulted. It's an unfortunate side effect at times and it happens. Ehh...move on.
This is one of the reasons I usually try to just stick to the subject at hand.
When I post a problem, any and all ideas are fine with me. I'll decide which I want to take and which I don't.
Some Ideas may spark a thought in my head that is not exactly what someone said but took my focus in that direction and gave me the some solution.
Some Ideas I think fit perfect and others I'll keep in my back pocket as a back-up should the first idea not pan out.
In any case I have no problem with what ever the poster believes I may need to check. It's always possible to miss the obvious.
Can't see the trees because of the forest kind of thing.
Last edited by vettebuyer6369; 10-27-2014 at 11:30 AM. Reason: edited out removed quote
#77
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,328 Likes
Guys, this looks like a pretty useful technical thread that the OP seems to be pleased about, regarding getting help. It would be a shame to delete it because people must continue personal squabbles.
There's more than one participant. I've tried to clean up most of the unnecessary commentary.
Please continue the comments and keep them on-track for the OP's sake. Additional bickering and piling on will result in sanctions for all participants.
#78
First Vettebuyer, thanks for cleaning up some of the responses.
Second I have been doing a little research to find reasons for spring surge and poor harmonics in a valve train. Here is some information I found in a hot rod article that might be of interest to those building or setting up their own valve trains.
From this article.
http://www.hotrod.com/how-to/engine/...-valvesprings/
Since the Dart heads are generically set up as a roller cam head it can leave entirely too much space from coil bind. In these cases with new more aggressive ramp rates this can set up an undesirable resonance and actually cause valve float or poor harmonics. The spring depends partially on contact with other coils to control it's movement.
In this case it may actually be necessary to shim up the valve spring to reduce the installed height and run closer to coil bind, as Scott pointed out, to stabilize the coils.
As the article points out the cam controls the rate of the valves decent to the valve seat not the spring. The springs job is to make the valve follow the cam's profile. So greater seat pressure is not a detriment to wear.
Over the nose pressure can be, but roller cams are designed to take more than flat tappets. So then lifter collapse would be the limitation mostly, and if the pressures were that high then a solid roller would be in order.
Thinking has evolved on how much safety margin is needed. About 0.060 inch used to be the textbook minimum, with more OK and even desirable. That's still an acceptable standard for everyday performance use, but Massingill says that in some cases "0.060 has become the maximum rather than the minimum." Godbold notes that "from high-speed video and testing, it is clear that adjacent coils contact as you approach the valvetrain limiting speed. Hence, modern springs are designed to run near coil bind and use the coil-to-coil interaction for improved damping at or near max lift. This interaction is one of the most effective means of dampening spring surge, but the valvespring must be properly designed in terms of solid stress to safely use this interaction." Depending on the intended use, the spring and cam-lobe design, and the engine builder's preferences, you will now see coil bind safety margins vary from as low as 0.015 inch to as high as 0.120 inch, with tighter numbers predominating on very stiff valvetrains. In a serious valvetrain, anything more than 0.150 inch can cause spring surge, which can greatly reduce the available spring load needed to close the valve.
#79
From this article.
From this article.
#80
Been doing this 40 years and learn all the time. Didn't realize that the recommended spring could actually cause harmonic issues from to much space from max lift to CB. Different springs seems like a better solution than shimming them tighter. Your already over recommended spring pressure on the seat and even more pressure at seat and max lift will be pushing your rocker capabilities, stress the lifter internals and increase loading at the roller lifter interface.
It kind of looks like the spring set up on these heads are heavy for the application. The springs need a diet. They are heavy and hard to control due to their own weight.
It seems like it could be better in this application to have a lighter spring then shim it up to the pressures I need to control the valve and not waste so much of the spring's energy controlling it's own surging.
Also in that article caught the part about shimming a max of .090" then if more is still needed, use spring locators.
