How to swap a 79 speedo into an 80?
I would like to swap a 1979 140 mph speedo into my 1980. What would I have to do to get it to register properly? Would it need to be recalibrated or would I just need to change the driven gear in the tranny? I searched and found a lot of threads on this with no definitive answer. Some threads say direct swap, others says you need to have it recalibrated, some say you need a traducer and still others say the driven gear will need to be changed. Anyone know for sure? My 80 has a turbo 400 auto tranny if that makes a difference.
Should be bolt in- These are mechanical speedos.
Speedos work in cable revolutions per mile.
IE 60 MPH is X number of revolutions.
If the speedo is calibrated to 0-60, 0-140, 0-200 etc shouldn't matter.
They should still be calibrated to X number of revolutions per mile.
We used to swap out the old 85 MPH speedos in GM cars all the time for their "Police" equivalent and never had to re-calibrate or install new trans gears.
While the technical knowledge required to pull off a speedo swap is fairly low, actually doing it doesn't qualify as something I'd call fun. On a scale of 5, tho only a 1 skill wise, I'd put the hassle level nearer a 4. Still, IMHO stepping up to a 140 (or 165) MPH one is definitely a worthwhile project. YMMV
How can that be when an 85MPH max speedo a completely different sweep has than a 140MPH max speedo?Seems to me that a 85max speedo would have to spin slower internally to make the complete sweep to a "pegged" 85mph,where as a 140mph speedo wouldn't.I mean if I was to take the face off my 140 speedo and put an 85 mph on,would'nt I have to run 140 for it to show 85?
IIRC speedo calibration is weighted magnetically relative to its given MPH range to register whatever speed is being input via the cable.
If that were the case, GM would have to list a separate speedo head for every axle/tire combination possible (which they don't).
That is why they have so many speedometer gear options in the trans-
Speedometers are calibrated to the 'face' they have, period.
You are comparing apples to oranges in your example above-
If you put a different face on the same speedo head then yes, it would need to be re-calibrated- But if you are swapping the entire unit, it's all good and it'll all work properly with no calibration required.
Nope.
