which intake and carburetor?
I'm about to put a blueprint 383 stroker in my 1980. It has a stock hood. I'm looking for a chrome intake and was wondering if you could recommend one that would fit under my
hood. Also can you recommend a nice 600 cfm carburetor and drop base air cleaner.
If you could post links for me to see them that would be great.
This is what ive had On my 80' with a stock hood a edelbrock performer 2101 with a qjet and stock dual snorkel air cleaner
Edelbrock performer 2101 with a 1" spacer 650 double pumper and spectre air box
Current setup is edelbrock victor Jr 2900 with volley 650 double pumper and spectre air box. I have about 3/8 clearance left
Picture is with performer 2101 and 1" spacer.
I don't have the tubes hooked up yet because I'm still messing with the carb tuning.
Location: Las Vegas - Just stop perpetuating myths please.
Whats wrong with a polished intake? U can see my polished Edel Performer Air Gap in my avatar pic. Fits under the hood of my '74 with the stock aircleaner nicely. Looks great with my polished Edel water pump. I think u can purchase Edel intakes in an Enduro Shine (similar to chrome) and polished both. I believe u can purchase Holley intakes polished also.
Dont know why u want to run a 600cfm carb on a 383" motor. And why run a drop base a/c unless u need one? The drop base is for a hi-rise intake like the Edel RPM. Most catalogs have the intake dimensions for comparisons - i know Edel does.
Do you know if the Weiand Street warrior is any good. This is the link to the 383 I'm going to purchase. I would like your opinion on which intake and carb.
http://www.blueprintengines.com/inde...1-engine-specs
The Street Warrior is a good intake. With the 195 heads and the cam that you have, I'd try to run a higher rise dual plane(Performer RPM), particularly if you intend to run a drop base air cleaner.
If you have the stock Q-Jet carburetor, I'd stick with that and get a Performer RPM Q-Jet to run it.
The money you saved on buying a carb could be put rebuilding the Q-Jet - with cash to spare.
I have a Holly Quickfuel 650 FS if you are interested.
I think with your cam and compression a single plane would be a better match. I like the Weiand X-CELerator Intake #7547-1 for your car and engine. But its not polished - u need to find a another shop that has that service if u really need it. A 600cfm would work better on a single plane intake for your 383" but u could easily go with bigger carb and make more hp.
Now that large cam will be a little more tame with a dual plane intake but i feel its a bit of a mismatch as if u wanted to make less power u should have bought a lesser engine - duration under the 220 degrees @ 0.050" range.
If your shopping for a new carb i think Holley, Demon, the original Qjet, Summints own brand carb, Edelbrock has theirs also - all have something u can use with quality. Its the used and rebuilt carbs that are more suspect. That and u need a spreadbore intake for a spreadbore carb then of course a squarebore intake for a squarebore carb - note some intakes will bolt on both the spreadbore and the squarebore carbs. U need to match them up before purchase.
Hope this helps more than it confuses you. If u need to just drop us a note/post before u purchase.
BTW nice engine.
BTW nice engine.
