I bought new lap and shoulder belts for my 73 Vette. The buckle on the shoulder belt is too big to fit through the opening in the seat back. No matter how I angle it, it will not fit. Any suggestions?
Yea, I had to remove that piece of plastic too. Another trick I used was to get a piece of tie line or something like a shoe string, loop it thru the opening of the buckle and get that thru the seat back first. Then use that as a little extra leverage to gently pull it thru. It is tight, but it will fit.
Use a hair dryer on the boot to soften it up. When it is soft enough, remove it from the buckel. Turn the buckel upside down and it will slide through the seat
Ed
