c3 window problems
Could also be electrical too.
Open the door and with the power on, have someone hold the switch in the up or down position (which ever position is appropriate in your situation), gently manipulate the wire bundle that goes between the door jam and the door. You can also disengage the protective bellows where it connects to the door and where it connects to the door jam. This will allow you to manipulate more of the harness. If the window reacts favorably to the wire bundle being manipulated, you need to run down the wire that is the problem and repair it.
If nothing happens, I would move to the switches under the console and check for power and continuity.
Good luck... GUSTO
Good luck... GUSTO
Received 1,468 Likes
Cruise-In II Veteran
Test the switch.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
