About to pull the trigger on a new crate Dart SHP engine
Old 10-25-2014, 10:02 PM
StingrayLust
StingrayLust's Avatar
Default About to pull the trigger on a new crate Dart SHP engine
So I think I've written off the big block temptation I had for a while as well as the idea of rebuilding my #'s matching block. I'm pretty much focused on a crate engine and the one I'm looking at is this one from TriStar Engines out of Wisconsin, about an hour away from my house. I actually went and toured their facilities a couple weeks ago.
http://www.tristarengines.com/catalo...der-heads.html
I'm looking to go with these options:
  1. Standard passenger side oil pan: Champ Pans, #CP60LTR
  2. Dart Pro 1 aluminum heads ($300 upgrade over SHP heads)
  3. the piston is .005" in the hole
  4. head gaskets are .041 thickness
  5. rotating assembly is internally balanced with 2 piece real seal
  6. they use the Howards Cams Retrofit Hydraulic Roller Camshafts 110275-12. 241int/247exh @ 050 lift, 294int/300exh advertised duration, 112 lobe separation, .545int/.565exh lift.
  7. The pistons are made my Icon, same company as Keith Black, it's just their higher end brand of forged piston.
Here's the basic info from the 406 web page:
Block:
NEW Dart™ SHP Block
Featuring upgrades including...
•True Priority Main Oiling System
•Siamese cylinder bores with extra-thick walls that resist cracking and improve ring seal for more power
•Extra thick decks ensure reliable head gasket seal
•Blind head bolts don't go through to water jacket
•Splayed outer bolts on middle main bearing caps
•All OE bolt holes for starter, clutch ball, etc...
•MADE IN THE USA
Short Block Features:
2618 Forged Pistons
Scat 9000 series Steel Crank (Optional 4340 forged crank)
4340 Forged Rods
Brass frost plugs
Moly piston rings
HP cam bearings
Cloyes billet timing set with torrington bearing
Howards hydraulic roller cam with Retro-fit roller lifters
Melling oil pump
Internally balanced
3.750 Stroke
4.155 Bore
Camshaft Advertised Duration:
Street/Strip engine: 294° Intake, 300° Exhaust
Camshaft Duration @ .050":
Street/Strip engine: 241° Intake, 247° Exhaust
Heads:
Dart™ SHP Cylinder head castings
Specs
►200cc Intake Runner
►64cc or 72cc combustion chamber volume
►Straight spark plugs
►2.02 stainless intake valves
►1.60 stainless exhaust valves
►Howards HP valve springs
►Howards chrome moly valve spring retainers
►Race Series roller rocker arms
►Chrome moly .080 wall pushrods
Features
►Premium alloy:
•A356-T6 aluminum alloy
►Manganese bronze intake valve guides extend cylinder head life.
►Hardened exhaust seats are compatible with unleaded gasoline
►Multi-angle intake seats and radiused exhaust seats dramatically increase air/fuel flow
►Cast, machined and assembled in the USA
Additional Parts:
SFI rated harmonic balancer
High capacity oil pan
Chrome timing cover
Pro Star polished aluminum valve covers
Horsepower: 530 (Street build)
Torque: 520 (Street build)
Starter:
I'm looking at the Powermaster Mastertorque starter #9000 for up 14.0:1 compression
Intake:Headers:
I'll be reusing my HEI distributor and wires, qjet carb, and factory style fuel pump.
So, what does the forum think?
SL
Old 10-26-2014, 01:19 AM
76strokervette
76strokervette's Avatar
I would go with the performer rpm qjet for the intake and talk to Lars about adjustments for the the carb and distributor.I know he has write ups on both.
Old 10-26-2014, 01:41 AM
63mako
63mako's Avatar
St. Jude Donor '08-'09
Huge cam for a street build. What compression ratio? Performer intake and cam are mismatch. Do you have a manual trans and low gear differential?
Old 10-26-2014, 05:30 AM
Gordonm
Gordonm's Avatar
with the above. Cam and Intake are not going to work well together. Also for that many cubes the 1 5/8 headers are to small. You going to want at least 1 3/4 pipes.
Old 10-26-2014, 05:37 PM
Karsten
Karsten's Avatar
I learned one thing while putting together a big Harley motor and the 2 things that will mess up any build is lack of Air/Fuel in and getting rid of the exhaust.
I was advised to go Quick Fuel 680 on my 375 HP 350......Qjet I think you will starve that motor. Then with the smaller tube headers you will back everything up.
Just thinking out loud, but it sound like one hell of a motor.
Karsten
Old 10-26-2014, 06:01 PM
MotorHead
MotorHead's Avatar
Location: Who says "Nothing is impossible" ? I've been doing nothing for years.
Get bigger heads, Dart, AfR, etc. 200cc is too small it's not a 350ci it has more displacement than the 396ci big block. Eldlelbrock RPM AIr Gap is a good dual plane and the classic Holley 750 DP to top it off.
Old 10-27-2014, 10:46 AM
StingrayLust
I'm trying to stay with the Performer 2101 because of my divorced choke and the hood restrictions. I have a SB with the LT1/BB hood.
Old 10-27-2014, 10:52 AM
StingrayLust
I have a choice of compression ratios on the web page: 9.4:1 or 10.3:1. The 10.3:1 they say is recommended for street/strip use.
I had a TH400 that I pulled out and going back in a manual hooked up to a LGT700.
The diff is a 3.36 that I had rebuilt years ago before I knew I'd be getting all of this, otherwise I would have gone with a 3.70.
I had also questioned the cam as the jegs web site says it's for circle track racing, that had me a bit concerned. Here is the response I received from TriStar about it:
When you look at cam specs online just take into account that a cam performs much differently depending on the engine.. When Howards Cams lists a description for a cam they are listing it generically to be used in an engine from a little 262 Chevy to our monster 427 small block Chevy. Cubic inches eats up duration.. The more the CID the more mild the cam will seem. You are welcome to provide a cam part number you would like us to install, we just can’t guarantee any sort of performance or driveability.
Old 10-27-2014, 11:12 AM
StingrayLust
<<<@!1!@>>>
The qjets from what I read are anywhere from 750-800 cfm. This carcraft article for a dual-plane intake test used a 750cfm Holley, and if I'm not mistaken, lots of big blocks also used the qjet.
That same article did use 1 3/4" dyno headers, so yes they would be bigger than the Flowtech 1 5/8".
What I need are some dirt-cheap headers to get me going as my budget is blown with the engine. If there are some bigger, dirt-cheap headers that will work, I'm all ears!!!
I see on eBay the http://www.ebay.com/itm/63-82-Chevy-Corvette-5-4L-V8-265-400-CID-4-1-OBX-Mid-Tube-Stainless-Header-/201134209968?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ed4887bb0&vxp=mtr quite a bit, but they aren't coated and aren't any bigger in diameter than the Flowtech.
Old 10-27-2014, 11:27 AM
StingrayLust
Honestly, the 406 TriStar offers is more engine than I really wanted. I had planned on just rebuilding mine to get to around 430 hp/torque.
But if I had TriStar build me a 383, it's the same exact cost as almost all parts are the same except for the bore. So who wouldn't just get the bigger engine? I'm seriously asking, it doesn't make sense to go with a 383 when the 406 is the same price does it?
Old 10-27-2014, 11:35 AM
Karsten
Karsten's Avatar
Stingray,
You might want to take a look at this 383 Stroker with 415+ HP and 450 Tq for 1/2 the money.
http://high-performance-engines.com/...duct_Code=HP94
Karsten
Old 10-27-2014, 11:59 AM
63mako
63mako's Avatar
http://www.summitracing.com/parts/ed...kit-components
Old 10-27-2014, 01:49 PM
DO2G
DO2G's Avatar
Pull the trigger! It will be a blast to drive!
Old 10-27-2014, 04:11 PM
StingrayLust
I worry about hood fitment with the RPM. I've got a SB with the LT1/BB hood and my original configuration I have maybe 1/4 to 1/2" clearance right now.
According to the CarCraft article I linked to earlier in this thread, the Performer vs the Performer RPM I don't really lose all that much:
Performer (2101):
Peak Tq: 494
Peak HP: 456
Avg Tq: 459.1
Carb Ht.: 4.60
Tq @3000: 470
Performer RPM (7101):
Peak Tq: 504
Peak HP: 470
Avg Tq: 468.3
Carb Ht.: 5.25
Tq @3000: 474
Looking at those #'s, if fitment is an issue I'm really not giving up all that much by sticking with the 2101. The engine already has more HP/torque than I wanted for my back end. Plus, if I find out that there is room for the RPM, the intake is easily replaceable down the road.
I always find these pictures useful:
Old 10-29-2014, 01:02 PM
StingrayLust
Default camshaft
So here's the cam that TriStar puts in by default for their 406:
http://www.summitracing.com/parts/hrs-110275-12
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,600-6,500
Intake Duration at 050 inch Lift: 241
Exhaust Duration at 050 inch Lift: 247
Duration at 050 inch Lift: 241 int./247 exh.
Advertised Intake Duration: 294
Advertised Exhaust Duration: 300
Advertised Duration: 294 int./300 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.545 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.565 in.
Valve Lift with Factory Rocker Arm Ratio: 0.546 int./0.565 exh.
Lobe Separation (degrees): 112
Camshaft Gear Attachment: 3-bolt
Camshaft Manufacturers Description: Rough idle, bracket race with excellent mid and upper-end horsepower.
Notes: Retrofit roller cam for engines that did not originally come with a roller cam.
I decided to use the Howards "Cam Recommendation" service. This morning I got an email from Scott at Howards suggesting this cam based on my specs:
http://www.summitracing.com/parts/hrs-110265-12
Basic Operating RPM Range: 2,400-6,000
Intake Duration at 050 inch Lift: 233
Exhaust Duration at 050 inch Lift: 241
Duration at 050 inch Lift: 233 int./241 exh.
Advertised Intake Duration: 286
Advertised Exhaust Duration: 294
Advertised Duration: 286 int./294 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.530 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.545 in.
Valve Lift with Factory Rocker Arm Ratio: 0.530 int./0.545 exh.
Camshaft Manufacturers Description: Lopey idle, hot street and bracket racing. 10.0:1+ compression ratio advised.
The RPM range that Howards suggested seems to be closer to what I would use. As the description states for the Howards suggestion is that it's a lopey idle instead of a rough idle, which I'm assuming means I'll have more vaccum.
I've calculated that with my 5-speed OD, at 70mph I'll be around 2100 rpm. Would I better off with a cam still closer to that rpm range?
Old 10-29-2014, 02:49 PM
MotorHead
MotorHead's Avatar
Don't get caught up in the Basic RPM Range. My 427ci Basic RPM Range is 4000-8000RPM, it runs just fine at 1,700 RPM at 70mph with a 3.08 rear end.
Old 10-29-2014, 05:31 PM
StingrayLust
Default vacuum
So I emailed Scot back at Howards asking if I should go with his recommendation or TriStars, and his response was this:
No they have done a bunch of dyno work so the cam they have in it will work the best
Here is the dyno sheet for their 406 ProStar build:
I'm thinking the 10" of vacuum @ 1100 seems a bit low. If I went with Scot@Howards original cam recommendation, would I get more vacuum?
To About to pull the trigger on a new crate Dart SHP engine
Old 10-29-2014, 06:51 PM
63mako
63mako's Avatar
You can drop the operating range about 500 RPM because of the bigger CI. The cam Howards recommended has 286 advertised duration. Motorheads cam has 286 advertised duration. The operating range your looking to use, your dual plane intake and 1 5/8 headers I would go with Howards recommendation and the 200 CC heads. It is a good match for your combination, be good for 6000 RPM shift points and the ports will match up pretty close although I would like to see the Performer RPM and 1 3/4 headers on it. If you went with a big single plane, 1 7/8 primaries and were shooting for 6500 RPM shifts use the bigger cam, bigger heads, bigger single plane, forged crank, 7000 RPM go solid roller and the bigger pieces. The default cam will make more peak HP but not in the range you will use it in and not average torque. It will barely be inching into the operating range at cruise. A well though out, well matched combination will outperform a mismatched combination especially on the street. Anything you add powerwise up top you deduct from bottom end. The cam Howards recommended will give you better vacuum.
Old 10-30-2014, 03:27 PM
StingrayLust
Not sure what you meant by "Motorheads", of if that referred to TriStar, and was your "Motorheads cam has 286" meant to say "294" instead as that's what the TriStar default cam would have.
I get real worried about a one-sized-fits-all engine. The engine may be setup for the absolute best HP/tq, but if my headlights don't pop up because of low vacuum, I'd be really upset.
The guy at Howards Cams I was in contact with, didn't seem to grasp my vacuum issue as he just pretty much said "yeah go ahead with what TriStar uses as they've dyno'd it".
I do plan on getting 1-3/4" headers, seems like the cheapest way to get into a set is with the Hooker 2134HKR Super Comps for about $463. I've read these hang low but found that they seem to fit well. I can always take them off next Fall and have them coated, spreading the cost the wife sees.
Old 10-30-2014, 04:05 PM
AirBusPilot
AirBusPilot's Avatar
The RPM air-gap fits fine under my LT-1 hood.
Quick Reply: About to pull the trigger on a new crate Dart SHP engine
