HELP! Shortest Air Filter Assembly needed or ideas?
ok...got the kit...probably wont use all the parts...
what did you do to the base to get it to fit the carb circle?...ie...the base has that lip? just trim it?
Thanks,
R
Thanks,
R
had a friend mention this...
http://www.summitracing.com/parts/edl-1002
he said we could modify its base alittle to get breathing room...
................bump.................... ...
thanks paul! good pic! nice bump! working on getting original working now...little concerned on space with your setup since it is not returnable if it doesnt work...
FOR the L88 base...it is almost a circle that meets the carb flange...but has 2 little lips that prevent it from meeting the base cleanly and being full circle...did you guys just trim those? or do they have a purpose?
