Saginaw steering column part interchange
Hi
I am new to the forum, so please pardon me as I try to post properly.
I am hoping it will be OK to ask a question about a Corvette style (Saginaw) steering column even though I am not using the column in a Corvette. I am looking for Saginaw steering column expertise and am hoping Jim Shea, (or another Saginaw expert) might help me out.
Can I assemble a steering column using the “mask jacket (#63)” and the “bearing housing support (#49)” and the bearing housing (#24)" from a 1989 Chevy S10 TILT ONLY steering column. And then from this point upward to the steering wheel, can I use the parts from a 1978 Chrysler (Saginaw) TILT TELESCOPIC. Will this work?
Perhaps an easier way to ask the question is…..Can the Bearing Housing out of a 1989 Saginaw TILT column be used in a 1978 Saginaw TILT TELESCOPIC column.
Thanks for the help
Thanks for the help
Hi
Thanks for the help
Thanks for the help
Jim
Jim, since you seem to be the column guy, I have a question. I am trying to find the electrical connectors that plug into the safety lockout switch on a Saginaw column. is there somewhere to buy new ones or will I have to go to a junk yard?
thanks
thanks
