Will this engine work in my 79 vette?
I know I've been posting alot of things to do to my car lately. It's i see the feedback and then do very few things. I have done a few things so far thanks to all of you. Here's my new idea. Somone locally is wanting to sell a 2006 mustang gt engine. So I was wondering would it fit in my car? And if so what all mods would have to be done to my car to compensate for that big engine?
2006 Mustang GT motor makes 300hp. I don't consider that powerfull
Yes, HUGE mistake.
Not only would a lot of adapting be required, and would your car's value plummet quicker than a Don Schumacher dragster does 0 to 60, but just imagine the backlash you'd receive for doing such a thing, especially considering the arguments which result from something as simple as misappropriating the term "Stingray". And, while I've never been accused of being any sort of Correctness ****, I suspect that mine wouldn't be the only ignore list to gain a new member. But, FWIW, there is no bad question. So, points to your for axing first.
P.S. Just to be clear, I don't like it.
you would have a battle putting that p.o.s in there, those engines are huge. measure to the outside edge of the valve cover and see how wide it is then measure the height and length . they aren't small engines except in displacement. and they don't make power where you need it o.h.c. motors lack low end torque as a rule. just an additional note the 4 valve version which uses the same block is larger than a boss 429 and they were huge. you can put anything into anything with enough time and money but this would be ridiculous. a mildly worked 350 would beat the snot out of it.
I know I've been posting alot of things to do to my car lately. It's i see the feedback and then do very few things. I have done a few things so far thanks to all of you. Here's my new idea. Somone locally is wanting to sell a 2006 mustang gt engine. I know how powerful that is. It makes my current engine look like a joke. So I was wondering would it fit in my car? And if so what all mods would have to be done to my car to compensate for that big engine?
Idk, it's just my car being that small l48 doesn't have the power I want.. Even with after market things under the hood. And a new small block chevy that makes decent horsepower made to fit in my car costs like 7 times more money. Ill try to find something else I guess but there's not really much more I can do to make the car more powerful.
Pull your L-48, install some better pistons (up the compression a bit. 10:1 or so), a set of aluminum heads and complimentary cam, a better intake manifold and some headers. You'll be in the 375hp-400hp (gross) range very easily.
Do you realize the cost of transplanting a modern engine, let alone one that will not bolt up to pretty anything you currently have?
The Chevy small block engine is THE cheapest engine to build hands down. If your budget is only 1/7th of that cost then there is no way you can afford what would be required to adapt that Ford engine to your car!
You would need a stand alone computer system, transmission adapters, custom exhaust, engine mounts, cooling system modifications, new fuel lines and pump, etc. That swap would be very expensive (even if the engine was free) and complex (are you an engineer?) just to install a 300hp engine. Your L-48 could easily be built to that level for under $1500 and be a simple project!
There are no stupid questions, but, there are stupid ideas and this is one of those!
Well GM made millions of LS motors. Get the higher hp ones out of transams, cameros, vettes. Years ago I put a late model motor in my 91 Vette
Start with a proper tune-up; make sure the carb is running well and set the distributor up with a nice performance curve. After that, headers, a mild cam and exhaust and you'll forget about the Mustang engine.
I'm not sure what your budget is, but it sounds like it's only $200-$300 dollars. If that is the case, you probably shouldn't be trying for an engine swap at this time.
In about a month I could be up to 5. If necessary which I think it probably will be.
First obvious problem is the dizzy is on the wrong end of the motor, It all goes downhill from there. For a solution, there are some great crate deals out there, start with a good basic one that you can add onto as your budget goes up. SBC really is hands down the easiest and cheapest to build up.
