Who makes the BEST Roller Rockers RR'S
If you have ever seen the havoc created when an inexpensive roller rocker decides to self destruct and run shrapnel through your new motor you wouldn't think twice about spending a hundred or two extra to buy the good ones. I seen a pro comp shaft system fail and take out a $10,000 motor. Guy thought he was pretty smart because he saved $400 over the Jesel setup.
The best stud mounted RR is made out of stainless steel, uses 7/16th studs, has the biggest diameter spring clearance, and has allen locking nuts.
You can't use short valve covers on gen 1 performance motors because you need taller studs and .100 or .200 longer valve stems for springs with installed heights of around 2.0 inches.
An often over looked part is valve stem lash caps......... I recommend them. They give addition rocker arm to spring retainer clearance and save the valve stem tips in the event of the lash becoming too great. Bigger surface for the roller tip to run on. They are cheap compared to the valves.
IMO the Crane gold stud girdles are the best made. They keep the studs from deflecting on even valve cycle and they clamp to the allen locking nut body so they can't rotate. Your valve adjustment doesn't change
I had the comp cams ultra pro magnum SS on my 383 and loved them... I got talked out of them for my 427 build... The reason was given was valve train resonance .... Had a hard time solllowing that but I just went with it do do the sourse...
Ended up with Crain ultra gold I think
I'll definitely go with the bigger stud
Im going to end up with the crower Stainless Steels or the Comp Ultra Pro Mag
George, now you got me interested in these caps
Received 3,043 Likes
St. Jude Donor '05
Back in the 90s I bought a set of Proform roller rockers I didnt know any better. 300 mi later one of them gave up the ghost on the fwy spitting needle bearings everywhere.
Have Jesels now absolutely love em! 0 deflection
Hated paying for them but knew that was about as good as I could get was tired of having parts failures. Good 7/16 stud and rocker probably would have sufficed but had it at the time so-
Lash caps come in various thicknesses. Like ,080 .060 and ,040 I have used the comp cams ones with my 10 degree retainer keepers.
I never thought about them until I had 1.56 diameter springs and my Comp cams 1.65/ 1.7 ratio steel RR's were hitting my retainers
yes I remember that
ok, how do I know the size I need?
I've already got my springs, locks and keepers. all titanium from PAC
don't remember the exact size off the top of my head. they're at home
and I just realized, there are no studs in this engine. don't know why I didn't remember this before
the trunion sits in a seat and a bolt goes through it, directly into the head. in order to run a larger bolt with this id have to pull the heads and have them re-drilled and tapped
yes I remember that
Paul you have a couple of disadvantages. His heads are 15deg ? And his drive-train loss is about 12-13% in C5 and up. Very hard to compete with 23 deg heads and a 23% drivetrain loss, his engine can make less power and still come out on top on chassis dyno. No way would I try and compete unless I went to different valve angle head.
#33
HOW ABOUT THESE ? THEY ARE IN THE C3 PARTS FOR SALE SECTION:
NEW-in-BOX Comp Cams #-1602-16 ULTRA-PRO MAGNUM ROCKER ARMS.
Only $250 & Shipped FREE ! ! !
Chevrolet Small Block Fitment.
3/8" Rocker Arm STUD Size (This is the Standard Small Block Chevrolet Size)
LARGER 1.6 Rocker Arm RATIO (Standard Small Block Chevrolet is RATIO 1.5)
Two rocker arms were removed from box to 'Photograph" thus 14-are still plastic wrapped!
ALL 16 of These ROCKER-ARMS are BRAND NEW & NEVER Installed.
Summit-Racing has them listed at $315.oo - - -
YOURS for ONLY $250 ! And SHIPPED FREE !
#36
the heads are ls6 heads with a lingenfelter world challange porting profile
id change them over to stud mount if thats the best route.
at what point in rpm or cam ramp up do you start seeing a difference in shaft mount rockers and at what point do they become necessary.
George my valve stems are 8mm
4.86" intake and 4.915" exhaust
#37
Shaft rockers like my local company sell offset shaft rockers,
http://www.tdmach.com/
#38
However I feel they are worth every cent. They make the whole valve train more stable and you can get offsets so your pushrods are completely vertical and in line with the valve
