What to Replace/Do While the Motor is Out?
Finally my new motor project is wrapping up. I have a list of a few items that I'd like to replace/do when I pull the old engine out. What can you add to my list?
1. Evaporator core and accumulator.
2. Right hand brake line that runs under the engine.
3. Borgeson steering upgrade.
4. Clean and paint The engine compartment.
I know there is a thread somewhere on this but I couldn't find it.
I replaced all hoses, belts, boiled the radiator, P/S pump. P/S ram, trans lines, heater core and motor, trans insulation, overflow tank, washer fluid tank, all head light vacuum hoses, manifolds, and other headlight parts, horns, cleaned up and replaced missing or worn wiring water pump, fuel pump, fuel lines and tubing, worn distributor with new HEI unit and I forget what else.
Karsten
Karsten
when i did my 72 engine bay earlier this year, i -
-replaced the engine, A/C and forward lamp wiring harnesses,
-replaced the vacuum lines to the headlights and others,
-scraped the crap off the firewall, primed and re-painted,
-replaced a lot of grommets,
-removed and painted the "A" arms, springs and main "X" member under engine,
-removed and wire brushed the front brake line, coil spring cover and brackets,
-removed the wiper motor and installed a new firewall "donut" seal,
-trans collar and new tunnel insulation when i had trans out recently,
should have removed the blower fan motor and cleaned out the box.
then replaced with a C4 blower motor.
would have been a lot easier whilst the motor was out, instead of trying from over the fender, thru the grill....
probably a lot of other fidlly bits while i was there, but just dont remember now.
Lots of great tips fellas.
I have rebuilt the front end with all new parts already and have replaced the motor mounts too.
Something else I thought of was to work on the headlights. I think the hood needs to be off to take the assemblies out. The side bearings need replacing. Boy am I getting a case of "while I'm at it" itis or what?
While the motor is out you can more easily replace old C3 blower motor with a C4 blower motor witha 10 gauge ground. You need to make a spacer to fit it. Do a search and you will see the mod I did. My new blower is nice and strong!
I just pulled my drive train .. Of course clean and paint but first. Remove Harness for wiring and vac system and then...
Re-route the wire and vac harness , replace as needed .. It eliminates the over the break booster hack GM created during its building of our cars.
I am also lowering the main harness at the firewall to form to the trans tunnel making that area clean and orderly.
I did remove my A/C and the box at the firewall .. That allows me to relocate the relay for the heater fan. When i am done it should put all wires and anything else out of site and what you will see will be very neat and be coming from a direction and routed in a way that makes sense
Gusset the lower control arm mounting brackets on the crossmember and re-weld and complete all the factory welds at that area.
May be a dumb question...but, my engine is out and A/C is non-functional. It has never worked since I have owned the car. The PO said she had the compressor replace but it still did not work. she said they then told her there was a "blockage somewhere". Is there any advantage to try to diagnose and repair while the engine is out?
