Unable to open both doors 77 Corvette
Hi
I locked both my doors the other day, manually and one at a time.
Now I can't seem to open them. They rotate both ways, no friction and applied wd40 to assist.
You get the initial sound that's it's about to unlock but then nothing rotate th other way and you get a similar sound again but I guess it's the mechanism rattling the rods etc. Any ideas otherwise I'm stuck? I've also tried the other set of keys but same situation. If I rotate too hard I'm sure it will snap the key off. I take it that unlocking is anti clockwise?
Simon
Simon
Hi
Simon
Simon
Otherwise, it's not going to be easy. There are two rods that run from the manual door lock on the inside. Twisting it, pushes the first rod, straight back towards the rear, where it is attached to a bell crank that transfers that motion upwards to another rod that runs along the back side of the door, straight up and down at a slight angle and engages the door lock at the very top rear corner of the door.
You want to pull this almost-vertical rod, straight up.
Load this pic in your browser as my company's deal, won't let me insert the picture and good luck, it's not going to be easy!
http://corvettec3.com/Scottwindow10.jpg
We just spent two hours last night, unlocking and opening the passenger door and that was with the window down!!! Is there any gap at all in either window? Because you might be able to get the T-Top off, by manipulating the latches.
Thank you very much
Simon
Clearest example yet, of exactly what part to push down. We accomplished it nonetheless, by pulling the rod up. Still wasn't easy. I'll have to look at it, tonight, to see if we could've accomplished this in an easier fashion as you described.
Thanks!
That's great thank you very much. How did younget to the rod to push it down?
It might help to gently put a wood wedge in the bottom of the glass to give you a little more room to work with...
50% Success
I spent hours threading wire, nylon lines to try and pull those T-Top levers but could not get the angle on pulling them down.
Went back to the drivers door and worked the key backwards and forwards again and again. No luck. Then tried tapping the side where the rods run down the door suddenly it gave way and unlocked. So, have taken trim off and lubricated all mechanisms. The passenger door will not budge, tried the inside latch to open but no luck. Can't take the trim off because the screws are also along the side of door but we'll think of something. Unless you guys have a new idea about this? Exhausted believe it or not but relieved that at least I'm in.
Thank you all for your help so far.
Simon:
Simon:
Simon:
Simon:
Next, if you need to remove the latch, that's a tough one too! Three screws hold it from the back edge of the door and you need to unclip it from the outer door handle and remove the rod. Then, you can see where the lock has a male-female thing going and you can maneuver the male part out of the female part, by simply moving it around.
Then you move the door glass all the way to the top. Not sure how my shop partner did it last night, but he spent ten minutes maneuvering the latch downwards, so we could get it out of the bottom of the door, through the open access hole (that you already removed the plate on earlier). That passenger door latch was thoroughly crusted and caked with hardened dirt and grease! It's soaking in a solution of Simple Green, while we speak and today, we're going to pull it out and see what we need to do to make it work.
I swear to God, that car is going to make me rebuild, replace, refurbish or have to lay hands on every single part it has!
Sheesh!
Thank you
Simon, I feel your pain. Last night, we removed the passenger side door latch. What a total b1tch of a job! You remove all the rods going into the top corner of the door, then you remove the screws holding the plastic 'funnel' that diverts rain water from pouring on the door latch and lock mechanisms. You can kind of fold it, carefully like a taco, to get it out of the square hole or better yet, remove the access plate at the bottom of the door and get it out from there.
Sheesh!
Sheesh!
Simon
Sheesh!
Sheesh!
It was a PITA.
Well you're certainly right with this. The right door is not unlocking even from the inside. So how would you suggest getting this door open?
I have a '77 that I bought last October...have not been locked out yet--only because I do not lock the doors typically...the key will NOT unlock the doors...it will turn the cylinder in one direction, but will not turn it to unlock...
spring time project to figure it out...
Try hooking something under the outer handle to pull it all the way up, then try unlocking. Sometimes if you turn the key quickly it will help. If none of that works, you will have to get the door panel off, not an easy job with the door closed.
Look over the second picture in post #4 above to familiarize yourself with the actual lever you will need to depress.
Then with the window down and using a 10-12 inch flat bladed screwdriver, work it down from the back of the window opening until the blade is resting on the lever. Then with a sharp wrap on the handle of the screw driver, the latch will open. There is no real trick to it, but it does take practice to get it on the lever. Heck after a few times, you actually be a pro at it.
Good luck... GUSTO
JM2cW
I have a bit of a challenge with the doors on my '76.
Well, I don't have so much of an issue as my wife does. The technique I've found that works is to insert the key and pull back out just a smidge, then (and this is the important part on all Corvettes) you rotate the key in the opposite direction of the UNlock position and then rotate it the unlock position.
Every Corvette I've owned is like that. Hope it helps. Also don't use any oil based product to lube, just graphite...amazing stuff.
I remember doing all that , replacing missing clips, new electric window motors, installed new latches ....only I got to use OEM GM part from the counter 26 years ago. I completely went though both doors , cleaned and checked the operation of each item. Installed new felts . It was a lot of work.
It was a PITA.
It was a PITA.
Tomorrow we will try to finish it. Want to take it to an 1/8 mile drag strip Saturday and see what it does.
A big thank you to everyone for their help as all is sorted. The advice with a screw driver down the window, the key in the lock and pulling the outer latch up at the same time led to the door opening. Now the mechanisms are a bit sticky and sometimes when shutting the door it doesn't shut properly unless you open and close the inner latch. So a bit of further maintenance with the inner workings is required I suspect.
Thank you all once again. What issue can I put to you all now?
