figuring rear end gears--What am I doing wrong?
I marked the driveshaft and one of the tires. Jacked the rearend up---both tires off the ground and tranny in neutral---rotated the tire one full revolution. The driveshaft turned 1 full revolution and part of another. Had my helper rotate the tire till the mark on the shaft lined up i its original spot---looked at the tire and the mark was almost exactly an extra 1/4 revolution of the tire. I expected at least 3 revs of the driveshaft. Where am I screwing this up???
1975 350 w/ th400 trans. tires are 245/60 15's.
Thanks. Stump
Thanks. Stump
You did the right way of determining the Gear Ratio but got the wrong answer. So this means there is something slipping, and that would be the Limited Slip, Posi Traction or what ever is in there. Try Turning the other Wheel and see what happens. If that doesn't work do it the other way around, turn the driveshaft x amount of times to get the wheels to turn one revolution.
This may be a dumb question, but are you looking at the drive shaft and not the half shaft?
I didn't check the other tire to see if it was turning, forward,backward or static. I was not marking the 1/2 shaft but the driveshaft behind the front u joint. Thanks for all the replies. I'll try the other side tomorrow and see what happens.
Stump
Stump
Nam Labrat
Received 4,176 Likes
This chart should get you close to the answer (even if a P.O. swapped "chunks" in the diff.)
72-75
Positraction 3:36 Ratio
AX
72-75
LR
72-75
Positraction 4:11 Ratio
AC
72-75
Positraction 3:70 Ratio
AB
72-75
Positraction 3:55 Ratio
AA
72-75
Positraction 3:08 Ratio
AW
72-75
AX
72-75
LR
72-75
AC
72-75
AB
72-75
AA
72-75
AW
I think the better way would be to rotate the drive shaft one turn and see how many times the tire(s) turn. This will give you the 'number' you are looking for. So if you turn the drive shaft EXACTLY one turn and the tire turns about 3.3 times then you are at 3.36:1. Best thing to do is scribe a small chalk line on each and maybe line it up with a jack stand or something then start. I don't think the limited slip would 'slip' just rotating by hand. This should give you exactly the correct ratio.
Jim
Jim
Jim
Jim
thegazman
Jim
Jim
thegazman
Thanks. Stump
Thanks. Stump
Exactly what I did but being lazy I went under once, marked the driveshaft and then slipped my iPad, on record, under the car and rotated the tire one revolution. Retrieved the ipadband watched the video.
thegazman
You are just too hi-tech for me. LOL I'm just an old farm kid from the central valley. We never had a TV until I was in high school.
