71 Corvette Power window wiring
Does anybody have a power window wiring diagram for a 1971 Corvette? No air. I purchased a new harness but the original has been so butchered, it's hard to figure out where everything originally went.
Mainly these wires. The fuse box wires are brown (old were pink). The orange with black tracer has a loop on the end as if it mounts with a screw. The red wire has a loop and an opened end (see pic).
Thanks, Bill
ht1663wb@aol.com
Thanks, Bill
ht1663wb@aol.com
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
My new one in tech pictures is specifically designed for the 70-71 cars..
Thanks for all the help,Bill
My circuit breaker is mounted onto the side of the square box where the brake booster it's mounted in the engine bay.
The relay, I think, is under the center console, mounted to the tunnel, approx under the radio.
Former Vendor
Are you the person I've been swapping emails with the last week? The breaker is out on the firewall.. around the booster. I'm at home I don't have a picture here to post for you.
Willcox
Willcox
circuit breaker on my '72.
Red wire runs around to the horn relay under the fender. orange/blk stripe goes thru firewall to relay.
power window relay circled, the black box is the wiper relay.
