1977 w/ zz4 engine water temp sensor
PHILLY JOE
Does the water temp. Sensor on the new block different rating. Should it be replaced with the original for correct temp. Reading. The new one on the block reads a little higher on the gauge although there is no overheating. Thanks
If not get a hold of Willcox Corvette who has just developed a part to get you gauge dialed in....in case you have to change out sensors due to the threads in the heads are different.
DUB
