Rear shock
Rear shock
I attempted to put my rear shocks on my 1980 and had a hard time getting the top bolt off. Once I took the bolt off the shock decompressed and the control arm sunk down. well now im trying to put the shock back in and im having a hell of a time alighing the bolt back up. is there a trick to it such as jacking up the arm? Thanks in advance!
Received 2,878 Likes
Hi cz,
Yes, raising the t-arm reduces the angle between the upper and lower shock mounts and will make it easier to install the upper shock bolt.
Good Luck!
Regards,
Alan
Good Luck!
Regards,
Alan
Received 1,468 Likes
Cruise-In II Veteran
I had the same issue on my 76.
I put the entire rear end up on jackstands and then used my jack to raise the control arm. Jackstands are cheap and NO home mechanic should be without them.
amen a thousand times. i have a 2 ton jack and im waiting till i get my window fixed to justify buying a $100 jack
