BW Super T10 to a Muncie M22
Are the rods and shifter from a BW Super T10 compatible with a Muncie M22?
stock shifter and rods from my 78.
Do you have a hurst shifter?
If so, it's pretty close. I'm using a Hurst Muncie shifter on a T10.
The 1/2 and 3/4 rods/levers are similar, but on mine, the orientation of the reverse required some engineering.
If I remember correctly, they are not the same. Back in the 70's when I was wrenching on Chevy's for a living, a guy brought in his Vette with a T10 that he let run dry. Rather than gamble on the rebuild cost, he had us put in a used Muncie and we spent two days trying to get the right linkage to work.
I took the T10 home and installed new main shaft bearings and synchros and the thing worked great.
NO! Parts aren't the same.....the shifter unit is but rods/arms are different. Hurst sells kits if you have Hurst shifter with just the rod/lever parts, if you have Corvette shifter just need rod/levers for BW or Muncie.
