Need help selecting heads for 454
I been reading & reading and cant seem get the Idea. I have a genv 454 with 27cc dome pistons, roller comp camp 273 grind with intake at 224 & exhaust 236 @ .50 with a 113 slope, vale lift .537 & 547. I want aluminum heads to clear the pistons. But all the reading about runners , ports etc is kicking my ***. Basically I want a daily driver with torque. Im looking to spend around 900per head if that helps. Weww I had to get all this is out man , I need help.
http://www.summitracing.com/parts/br...make/chevrolet
Or if you can swing the extra and deal with the 3/8 raised exhaust ports.
It looks like im getting Brodix race rices. One thing though,do u guys think I should have them looked at after I get them? Or redo the valve job.?
They checked the spring clearance and even modified them for the ½'' temperature sensor. They also fitted the exhaust valves with seals.
I got them with the CNC chamber option.
/Karsten
