Small block Serpentine set up on big block?
There was a tread about Big block brackets that a fellow said you could use small block serpentine set up so I wanted to start a new thread rather than high jack that one.
A great guy and friend sent me a small block serpentine belt set up, that I admit I didn't look at yet since the car is still at the shop...
So is this true??? can the factory serpentine set up be used on a bb car?
In my case I have power steering, and will add AC,
I also want to add a spreader bar since I run a heavy old bb,
Many thanks!
Many thanks!
Many thanks!
Many thanks!
Several years ago, someone on ebay was selling adapter plates that would allow the SB serpentine kit to be mated to a BB. I bought a set of the plates, and now I have a BB engine setting on a frame with the SB Serpentine kit on the engine. I think, the AC compressor will be too high for a BB hood...even a L88 hood. I think that if the adapter plates were redesigned, the AC compressor could be lowered.
GM makes a Serpentine kit for BB's. Forget about it. All the mounting brackets are cast iron. The GM Performance Parts catalog BB Serpentine kit, with accessories, weighs 105 pounds. The GM Performance Parts catalog SB Serpentine kit is much less weight,...it has all aluminum brackets.
C3 Big Block serpentine belt drive
So to this date,03-01-2015; no one has a big block in a C3 with the serpentine belt system mounted on the small block brackets and be able to close the hood.? Least wise I have not been able to find a thread about it. One member said he spent $2800 for a vintage air front runner and still had to do a lot of mods to get it to fit?
Add... you do have to run the underdrive crank pully to clear the cross member. Stock one is to big in diameter.
Did you use the adapter plates commonly sold on ebay ($150) behind the small block brackets and did you use the GM stock AC compressor? Is your C3 hood the stock clearance? This is a way cheaper way to go if you can get the brackets, pulleys, alternator, ac compressor, water pump, etc from a u-pull-it salvage yard. But, didn't want to go through the hassle if it won't fit under my BB stock hood. I think the R4 GM ac compressor might mount higher than an after market Sandan AC compressor.
Here is my link to a post I did. I converted the GM BBC kit to work.
https://www.corvetteforum.com/forums...ulley-kit.html
Which crank pulley did you run? ( brand and part number?) I had to notch my frame out
I have a SBC Chevy serp setup on my engine right now. It is actually off of an early 90's S10 V6 (they used the same setup as the sbc). Bought Kwik perf plates and got the bracketry out of a junkyard for basically nothing. I'm far from being able to comment on hood clearance at this point as I'm in the middle of a frame off, but from preliminary measurements it will be tight, but should fit under the hood. I'll have roughly $300 in the system (including the reverse rotation pump) when done.
..About the no heating problem, I have a Be Cool Big Block radiator for my small block ZZ4 running pure ethylene glycol...no water at all...cold as a witch's tit.
