69 How to replace heater core
Hey all- anyone ever replaced the heater core in a 69 L46 no A/C? Can you replace it by removing that cover in the engine compartment or do you need to get the dashboard out? Just trying to size up the type of job this is because I have limited garage access. Thanks in advance for any comments/advice/help.
I have a 69 L46 and replaced the core. You remove the passenger side lower dash panel and if I remember correctly, remove the radio. It is explained in the 69 factory Chasis Service manual.
Thanks for responding. It looks like that cover comes off and it should be right there. Another member replied and said you need to get it from inside so I'm surprised about that. I hate taking the dashboard apart, stuff can break so easy.
2017 C3 of Year Finalist
Hmm, I've tried to remove heater core in my 71 vette with AC but I couldn't remove it from the inside. Or did I just give up too quickly? What about evaporator core? Can you remove that without too much hassle?
You can see the stud that goes through the firewall.
