how much horse power is to much?
Nam Labrat
Received 4,174 Likes
500+ H.P.?
"In my dreams!"
I haven't owned more than a 200 H.P. car in 40 years... so my 350/300H.P. engine seems more than enough.
The thing I've learned about Corvettes is......."They want to go in circles at the drop of a hat......or foot".
When I think back, what other members said is true, though....You can get "used to" more H.P.
Just be ver-r-r-r-y careful with it.
"In my dreams!"
I think about 1200 rwhp is the point that its too much...No matter what tire/suspension you put on it will allow it to hook under 80 mph... Traction control is a must.
Jim, I bet your car is straight up insane... I imagine you are well over 1k to the wheels with only 10 psi.
I think you are just bragging how mean your car is,
I have no idea how much hp is too much but I dont even know for sure what is enough, some people love chest thumping bragging rights,
What I do believe is important for any build, street car to track beast is the owner/driver can handle what they have and if they can't they do what it takes to be safe and handle what they have,
Since I have no experence with the type racing you are into I would suggest you find other fellows who run c3's in the same events and see what the savvy fellows run to hook up and control what hp they have, spinning aint winning ( unless it's a burn out contest )
I see several fellows post on here that sound very savvy with racing their c3's I mean the real racers not the street car go fast wanna be's see what the racers think, get their opinions...
its a small block 427, had a lot of help hear on the forum getting it together,,
It's such a tough one.
I had a 2007 Z06 for 2 years and a 2009 Z06 for about 4 years. It was a weird conundrum. Felt like too much power and not enough power. For the first 6 months it was great, even scary. Then I got used to the tirespin and going sideways and, more unfortunately, got used to the feeling of thrust.
There were times I actually thought the car was down on power. The thoughts of mild cams and LT headers, cold air intakes, etc adding 100+ hp frequently came to mind. But I tempered it with having a car that would obliterate the tires in first gear and was a bit scary on uneven or less than perfect pavement in any of the first four gears.
And now I have the engine in my 78 - which isn't as fast, and yet I have the same problem. I'm tempted for more.
I make myself happy by taking other people for rides and scaring the hell out of them. That's nearly as good as remembering the first time I got on it in the 2007 Z...
Got stronger lug nuts:-) and a rear end.....
I know what You are talking about. Since Your a Road Racer You are all ready in a best case scenario, as in You are at speed in most all of the time, and there fore more controllable. As said above I would work on a Flatter Toque Curve. With my car I found that I could push the resume button on the Cruise control at 80 mph and have the tires break loose. At the Nevada 100 I could get up to my 140 mph speed quicker than most but that was only an advantage for the first mile. A stock car could go just as fast for the next 89 miles. Every thing I have done to the car since is to make it easier to drive. Flatter Toque Curve, shorter rear end Gears, lighter Clutch pressure, finer tuned Suspension.
Myself, as well as my whole family are into racing,, and Resto-mods as well as original/stock. I on the other hand think the "customs" are usually flat out ugly and gody.. but if you were to post a picture of one of those, as maybe yours... should I ask if you are bragging? ... and since you have no experience racing, how are you capable of answering my original question anyway? Much less understanding it.
CI 5 & 8 Veteran
I dough-no but I'm going to have a good data point shortly.
This was the first run, we tweaked the tune to top out at 750hp
Pretty sure I will be overhauling the suspension as you guys say......hopefully before I put it in the ditch.
The general consensus on various performance websites is 500rwhp for the street. The car would also have a proper wheel/tire combination for 500rwhp, along with sufficient braking.
I study the mods done to modern cars to get ideas for my cars. A mod'd C6 Z06/ZR1 will easily put down 600rwhp. The cars are running 20 x12 rear wheels and performance rated tires. They have abs, stability control, and all sorts of computer nannies to keep them out of a ditch.
Another option is to study "drift cars". A vintage corvette with 500rwhp on stock wheels/tires would make an excellent "drifter". lol
What if you put in a higher gear ratio rear end. 3.08, 2.73 etc.
From this hot rod article;
http://www.hotrod.com/how-to/transmi...ow-gear-works/
In addition to changing the direction of power flow by 90 degrees (from the driveshaft to the axles), the purpose of the rearend gears is to multiply the torque delivered by the engine and transmission. Gears can be thought of as complex levers. In other words, they provide a mechanical advantage that multiplies work—in this case, torque—to help the engine's power move the vehicle. Lower gears are like a longer lever: They provide more mechanical advantage. Higher gears are like a shorter lever: They provide less mechanical advantage. It's similar to when you use a long breaker bar instead of a short ratchet handle to remove tight lug nuts. Just like a long bar puts more torque on a lug nut, lower axle gears provide more torque to the wheels.
It's very easy to calculate the torque multiplication provided by your axle gears—just multiply by the gear ratio. For example, let's assume that the engine and transmission are delivering 100 lb-ft of torque to the pinion gear. If the gear ratio of the ring-and-pinion is 4.10:1, then the output torque is 410 lb-ft (100x4.10). Similarly, if the gear ratio is 3.08:1, then the output torque will be 308 lb-ft. It's easy to see that the lower 4.10:1 gears put more power to the ground than the higher 3.08:1 gears. Keep in mind that the engine's power has not changed but that the available torque to the tires has.
If you want less torque to the tires to make it more manageable and hook up better this is one way to do it.
I remember gearing up my YZ250 to get less torque and thereby less tire spin on hard pack. In a two stroke , as you know, power is peaky and sudden, producing less torque at the rear wheels made it much more manageable in turns and actually made me faster.
I say throw money at the suspension or change the gearing up. I'm making the same power in a rotten chassis with every single bushing in my suspension shot and I handle it just fine. If you can put the pedal to the floor and not kick the *** end out, it's too slow. Racing (in any sense) is about throttle control and proper suspension tuning
I think this is where modern control systems have an advantage. Having the ability to make more power, but the ability to turn the "tune" down to match the conditions (to me) would be the ideal. The Top Fuel examples above cannot always use the power available, and have engine and clutch tuning so they can match what they can put to the track.
Definitely depends on the application and the purpose/set-up. Reference or comparison between a modern Top Fuel drag car, with optimized chassis and a 50+ year old Corvette design is just absurd.
I tried to hint at the topic in this thread. As far as I know, these are the two most successful, current drivers of our platforms, and each has made the most of chassis stiffening, available aftermarket mods and modern grip. Notice the disparity between the two in terms of power...IMHO the "too much hp" answer is somewhere between these two.
https://www.corvetteforum.com/forums...ette-p-rn.html
Are you thinking you'd be faster or at least get more enjoyment out of things if you could tone it down a bit? With your intake, a few restrictor plates might be worth trying...? We call you Red Dragon...
#33
Paul: Have you considered doing L88 flares so you can run more wheel and tire? Your rwhp is +- a stock C6 ZR1. If you had Zr1 like rubber, the car may be more stable, assuming you've done suspension and brakes.
My car is not completed yet, but I ran 18 x 12 rears and 18 x 10 fronts with Michelin PS2's. The same combo in 19's would have been better as there are more tire options.
#34
Well I don't know, but when 63mako asked me what power I would like, when I was in the process to buy my sbc 427, I said 500hp, no more, I don't need it.
I think that max. 500hp is a good choice for someone like me, driving with my kids, doesn't race ec ec.
I'm happy with my sbc 427, but I think a nice build 383 or 400 with 400hp would be enough for most. (in a old car)
#35
definitely my next move
the L-88 flares are a possibility if the new tires prove to also be non productive. You are running 10's up front? i was told 8" is as big as you can get... ????
#36
I have 550hp, and it's controllable, by me at least.
Sounds like somewhere between 550hp and 650hp is the "event horizon".
Btw, no way can I do a burn out at 80 mph, that's insane!
#37
Lets say it is right 600hp and all associated components in the drive line are in pace to handle it. ( Including tires ) lol got ya paul ..
The best way to keep it usable is with electronics , I new going into my 427 build I would need a way to control output to match what I was doing under driving conditions.
One solution I looked into was the MSD Grid system with the idea of gaining control of the motors power output sort of like how a ZR1 does it with launch control. I had a fast FI system so I thought sweet ill combine the 2.
However after more research I decided on dropping the FAST FI .. And going to the Holley HP sequential multi port FI because this allows every thing the GRID from MSD does and it does it in one package so that I will not have a FI computer and an ignition system computer. I end up with it all in one system.
I expect with this immense amount of control over the motor I will be able to get all power to the ground , do it fast and not wast it on tire spin.
#38
Just for clarification before we start mixing/cloudy the issue, the HP i was talking about is GROSS HP, not NET, Not RWHP, all a little different.
550 Gross HP is probs about at best 450 RWHP, more like 400-425 RWHP in a C3.
The 650 NET HP in a C7Z06 or a 505 NET HP in a C6Z06 is VERY different than 500 Gross HP in a C3....
Just to be clear..
Just to be clear..
#39
#40
CI 5 & 8 Veteran
The OP is asking, IMHO, How much is too much HP for "his" intended application. Like any system design, you have to trade all the requirements against what you want the car to be.
In my case, being a retired McDonnell, Boeing engineer, this is a hobby, so practically and to some degree cost was on the back burner. I wanted to keep the basic 69, L88 hood interface and its basic original look. That limited things like intake and head height, which then limited the engine performance. I still wanted to optimize what performance I could so, the all aluminum Dart 540 ci with Holley EFI was a given for me as a BB guy since my younger days. That makes the engine very light and street tolerant with plenty of performance. (750hp)
I hooked it up to a Tremec TKO 600 and plan to replace the 411 rear with 370.
I am taking a long look at the Ride Tech system for suspension upgrade. Hoping the cost comes down a little.
Bullshark
P.S The Holley EFI system will support adding Traction control, so that's probably on my list of additions.
Bullshark
