how much horse power is to much?
#121
I'm about 568 hp at the crank on our build spec. I'm running it through a 3600 Vigilante converter through a rather beefed up 4L60e and putting it to the ground through 3:73's. I haven't dyno'd it yet, but I figure I'm losing at least 100 hp through the driveline, probably more. 1st gear is plum nuts and 2nd isn't far behind it. 1st seems to pop me out of the hole real fast but 2nd hits 'uber fast. I could have went with 3:50 gears and done just fine, but hey. the 3:73 cogs are fun, and the overdrive makes it all come together in a fun street ride. I've done a little to the rear suspension, and haven't broken anything yet...but I am considering installing an Eaton blower and give her another buck-fifty to two bucks to the rear wheels. My ONLY fear is hitting the point where I DO start breaking stuff. I think the automatic transmission and torque converter tend to absorb a lot of immediate torque from the crankshaft that doesn't get absorbed when slamming a stick and popping the clutch. In the past, that's usually when I broke 'stuff". I figure with the blower, I'll have maybe 550-600 hp at the rear wheels, probably pushing the rear end survival to it's limit. This said, I have a son with an LS in a Trans Am with two huge turbos behind a 6 speed stick. He's pushing 1200 hp, and frankly, even with all he's done is the area of suspension and rear end mods, that car is CRAZY scary at any speed. You might think you've grown ***** at 100 mph, then floor the gas pedal and find yourself going the wrong way. THAT is TOO much hp for the street especially on street tires.
Pauldana: I hope you consider running a wider tire than an extra inch. An extra inch will only give you an 18 x 9 rear wheel/tire combination. Another option is to go with a milder cam and take some hp off the table.
You can match the wheels/tires and suspension to the hp, or match the hp to your current combination. The cheapest route is to match the hp to what you have.
When your ready to build again, you can do so.
#122
Here is 850rwhp on a GOOD tire in a chasis that doesn't hook near as well as a C3...
Plenty safe and in control...
Here is a tip, don't drive a car with 600+ HP on 300 tread wear tires whether it be on a drag strip, road course and damn sure not when doing acceleration runs on the street... That is just retarded...
Here is 650 crank HP in a C3 chasis with some MT drag radials, 20 mph roll in 1st...
Point is, get some tires that fit the intended usage of the car and practice in it.. If its gonna be a road course car, get some Nitto 555RIIs or Toyo R888s, both are great for road course and allow the power to hook...
#123
#124
C5Z, 402/F1R, auto, 60-150 mph roll - YouTube
#125
My 406/F1R six-speed stock suspension C5 with 800ish rwhp will bite you in a heartbeat on the street. That's on 345-35-18 Hoosier R6's. It was the same way on MT's, Toyo TQ's, and BFG Drag Radials. I can usually roll into the throttle in 3rd gear and 4 times out of 5, it'll hook. That 5th time...look out. You gotta be on your toes. It's fun but you gotta be careful. My big-block C3 with 500ish crank hp and 275-40-18 street tires hooks fine (needs more power - lol).
