HELP on removing Front Wheel Spindle Bearing Hub from front rotor
Have the original (5) riveted Front Wheel Spindle Bearing Hub to rotor. Looking on line, they are talking about a punch mark in the rivet, then drilling a 5/16 hole in the center of the rivet, then punching them out. They say no rivet (or other) is needed as the mount between the wheel/rotor/ hub secures the rotor (like the new cars) So - any ideas? I did the drill and punch, and they are not even coming close to budging. Might encounter a similar situation on the rears?? Thanks
