Harmonic balancer/timing chain cover question
Does high horsepower 427's have an 8" balancer and if so are the covers the same as a 454? I have a 427 engine with a 454 crank and want a correct looking cover not an after market cover with a bolt on tab.
427 Rat is internally balanced, 454 is EXTERNALLY balanced so harmonic balancers are different wont interchange. Timing cover tabs are the same, both 8" OD balancers
