Starter Problem
Old 03-06-2015, 01:30 PM
Franks73
Franks73's Avatar
Default Starter Problem
I installed a new starter, and new battery. Starter worked great when the motor was on the Dyno. Now in the car, it seems that not enough juice is getting through to get the starter gear to engage the flywheel. If I line the teeth up, it works. If I put my battery charger in "jump" mode, 55 amps, it will work correctly once or twice. Cleaned battery ground to chassis. Have two grounds from motor to chassis. Ran a newer cable from battery positive, to the starter. No change. Could it be an ignition switch issue?
Old 03-06-2015, 02:38 PM
Tampa Jerry
Tampa Jerry's Avatar
Received 1,324 Likes on 957 Posts
Default Starter
It could be your switch or a bulkhead connector from the engine compartment to inside the car to the switch. To test the starter and bypass the switch and wiring, use a remote starter switch. It's the same switch setup that was used to start your engine while it was on the dyno. Jerry
Old 03-06-2015, 04:34 PM
Franks73
Franks73's Avatar
Default Starter trouble
Thanks for the ideas. This 73 has been one challenge after another.
Old 03-06-2015, 04:40 PM
doorgunner
Nam Labrat
Support Corvetteforum!
doorgunner's Avatar
Received 4,153 Likes on 2,726 Posts
Hang in there.....my challenges come in groups of 6!
Check out/click the thread below....members have given me many good ideas.....
https://www.corvetteforum.com/forums...k-starter.html
Old 03-06-2015, 09:36 PM
Franks73
Franks73's Avatar
Default Starter problems
Thanks very much! The people on this forum have been a big help!
To Starter Problem
Quick Reply: Starter Problem
