C3 Long Water Pump
Not if you plan on having any belts on it. The pulleys will not line up and then you would have to try to find a pulley that would work....and if you try to extend out your crankshaft pulley....you may have an issue with the cradle now getting in the way....and forget about doing anything with the power steering pump pulley.
Honestly I do not see a reason to change it to a longer one...but you did not add anymore to your post but a basic question....so it is all guess work.
DUB
DUB
You can bolt it to the engine but nothing will work that attaches to the front of the engine....ALL Corvettes whether BB or SB engines use the short pump....period.....
Nam Labrat
Received 4,153 Likes
Short pumps come in two different lengths/hard to notice/ from the back cover of the pump to the engine block depending on the year----I think....the correct pump will bolt on without having to add extra gaskets.
You can, anything can be done but I think the question is why, and what would it accomplish when completed, compared to the original set up ? All brackets and pulleys would need to be changed.
Corvette - Unique in Water Pump Ways
To be precise the water pump for a 71-82 small block Corvette is neither short or long;
Short Chevy Pump = 5/8" pilot diameter & 5-5/8" block to hub distance
Long Chevy Pump = 5/8" pilot diameter & 6-15/16" block to hub distance
Corvette Pump = 3/4" pilot diameter & 5-13/16" block to hub distance
