Vortec heads...what exhaust headers to use?
Install a GM 350 HO engine in my '80 corvette. The engine has vortec heads on them and I am told that a special exhaust manifold is required due to the exhaust port shape.
Any recommendations???
The vortec heads are D-Shaped.
I am using Sanderson Headers where the flange / header starts with a D-shape and then goes to a round pipe.
If you are using smaller dia pipes, then it is possible that some of the exhaust port on the heads will be cut off. How much it effects flow depends.
Larger dia pipes may completely cover the exhaust port and therefor have no effect.
