Head light override knob?
Old 03-27-2015, 08:50 AM
Franks73
Franks73's Avatar
Default Head light override ****?
There is a small black **** under the dash below the steering column. I believe this is to open the headlights, if they fail, on my 73. It seems frozen. Shoud it rotate, or go up and down? Thanks guys.
Old 03-27-2015, 09:00 AM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi F,
Yes, you pull it down to open the headlights without using the headlight switch.
Then push up to close them.
Regards,
Alan
The ****:
The vacuum switch on the left:
Old 03-27-2015, 09:13 AM
65GGvert
65GGvert's Avatar
Received 3,206 Likes on 2,297 Posts
You have to pull down fairly firmly to get it to move. I assume from your forum name you have a 73? It's good to mention in your question in case there are differences
Old 03-27-2015, 09:49 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
There is also a trip odometer reset **** under the dash. The owner's manual shows it.
Old 03-27-2015, 11:23 AM
Franks73
Franks73's Avatar
Default Headlight override
Originally Posted by Alan 71
Hi F,
Regards,
Alan
The ****:
Thanks for the help!
Old 03-27-2015, 11:25 AM
Franks73
Franks73's Avatar
Thanks for the info! I did mention that it was a 73, good reminder though!
Old 03-27-2015, 11:30 AM
Franks73
Franks73's Avatar
Thanks! I actually had to move that out of the way to install the new AC duct from Vintage air.
Old 03-27-2015, 11:32 AM
65GGvert
65GGvert's Avatar
I didn't see that the first couple of times I read the question. I see it now though. Were you able to get the lights to pop up? I assume you know the engine needs to be running so you have vacuum?
Old 03-27-2015, 11:53 AM
Franks73
Franks73's Avatar
The engine should be running soon I HOPE! Amazing the challenges that have popped up. I was putting the dash back together, and trying to understand the piece. Halfway expecting to replace it like so many other parts.
To Head light override knob?
Quick Reply: Head light override knob?
