1982 horn pops fuse every time it is honked
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The picture below will help you diagnosis your problem. Because you are blowing the fuse instantly, I would skip the first two steps below and pull the relay, jumper power and see if the horn blows. If it does then I would replace the relay.
Willcox
