Power Steering and Altenator Brackets
Received 1,469 Likes
Cruise-In II Veteran
The AIM shows you how to do it. Do you have the AIM?
Received 3,138 Likes
https://www.corvetteforum.com/forums...lve-cover.html
But that was the body, sounds like you just need to re-clock your alt to move the ground wire.
I recently changed to a CS144 alt and when I did I modified the upper bracket to give more room at the valve cover so that's one issue gone
M
Re-clock a 10si (12si also virtually the same)
https://www.corvetteforum.com/forums...lternator.html
M
M
M
M
Later, Rog.
P.S. I'm close by in Brooklin.
