Calling Richmond 5 spd Owners...Leaks?
Have a 71 vert with the Richmond and Hurst shifter. Has 3.08 gears.
Have some fluid leaks seem to be from trans shift cross shafts. There may be others.
Anybody have a source for seals for the shafts or have experience with other leaks? Also what fluid is recommended?
As a side note, the Hurst has a problem where the stick sits forward about an inch too far forward in the console plate. The PO cut the divider to allow getting into 1st, 3rd and 5th.. This is just info for anyone who might search for info on this trans. For now it works for me too.
Good luck .
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I've had the earlier Doug Nash 5 speed for years. It's my understanding that most of the Nash parts carried over to the Richmond design. I've bought most of my parts from Fortes Parts Connection in Massachusetts.
Had good luck with sealing up the transmission, other than occasionally a slight drip where the two case halves came together. I'm told there's a specific RTV type sealer that is supposed to work well sealing up the case halves, but I can't recall the name of the stuff at the moment (I just used the RTV stuff I had in my toolbox at the time).
RE: case halves "IMPORT GREY" RTV works well. I'd also suggest Hylomar. Valco Products handles it. Hylomar was developed to stay tacky and seal joints in Rolls Royce radial engines.
FYI Valco makes great alternatives to loctite and rtv and theyre an american company
