Headlights open but not together
This is on my 77. Both headlights open and close as they should but they don't operate in unison, should they? If it makes any difference the drivers side opens and then the pass side opens a few seconds later. They do make a pretty good clunking noise upon opening. Is there something I should check on or should I just be thrilled they function? Thanks for any and all help
The short answer is NO, they will not open in unison.
The longer version is the headlights on your car are on two separate and partially isolated vacuum systems. Theoretically they will open in unison if everything is functioning perfectly, but in the real world that seldom happens.
On most well functioning systems the headlights open and close within a second of each other. If one of your lights is lagging behind by several seconds it's usually the relay valve associated with that headlight that is at fault.
Received 2,878 Likes
Hi d,
The system is designed so that the headlights open simultaneously….. and on many, many cars they do. We hear only about the cars on which they don't.
Because there are 2 separate vacuum relays controlling 2 actuators it's possible for them not to.
The easiest way to get an idea of what's going on is to reverse the hoses (large red and green stripes) running from the relays to the actuators.
This allows the opposite side relay to control the right and left actuators.
If the slow opening door switches to the left side you'll know it's a problem with the right side relay.
If the right side door continues to hesitate opening you'll know it's the right side actuator.
So, give it a try?
Regards,
Alan
So, give it a try?
Regards,
Alan
Hi d,
So, give it a try?
Regards,
Alan
So, give it a try?
Regards,
Alan
I've always understood that they would not open in unison. The drivers side would always open first because it gets the vacuum first because they are routed in a series. I've even been told that NCRS judges will time the units fully expecting the left side to open first.
Hi mg,
I really don't think any NCRS Flight Operations Judges are 'timing' the open/close function, and also, I believe the expectation for a system operating normally is for the doors to open and close very close to simultaneously.
Regards,
Alan
Regards,
Alan
Alan, just curious what you consider Simultaneously? I've spent a lot of time working on my vacuum system and the right headlight still trails the left by about 1/10th of a second. It's about as close to perfect as I've been able to obtain (or seen) but if you are watching it's easy to see one light is trailing the other slightly and I get two distinct clicks instead of one if they were opening in unison.
I'm just asking because I want to know. I've only been around C3's for two years now and still have a lot to learn. Thanks for all your input, I've learned a lot from your posts.
Hi I,
If you can hear 2 different clicks (I'd say bangs) I think they can be closer.
I guess I would say if it happens close enough together that you don't even have time to begin to wonder if the second is going to open or close you're doing fine!
Regards,
Alan
I still have all the original components and hoses and they open and close at the same time.
The point that mg raised about the difference in length of the servo supply hoses has no effect once the engine is running, and the vacuum is supplied and a reserve stored in the tank.
Regards,
Alan
Another factor is the time it takes for the vacuum system to leak down after engine shutoff. If it will not hold vacuum for more than a minute or 2, you have vacuum leaks that will affect operation. FWIW, both of my cars hold vacuum well past the NCRS standard which is 15 minutes I believe.
Thanks!
