Problems with rear lites
when i put my turn sigaal on ,on the right side the left side blinks very dim,is this normal? how can i correct this?not sure if i should replace harness or what.
That's a sure indication of a bad ground. It could be at the socket connection, or it could be the metal base of the bulb isn't making good contact with the socket. The bad ground could be on either side. The voltage is feeding through the wrong side to ground instead of the correct side. The first thing I'd do is pull the bulb and clean the base and the inside of the sockets. (disconnect the battery so you don't blow a fuse), then I'd check the connections between the sockets that provide the ground. One other possibility, though remote is that one of your filaments in the bulb is shorted to another and feeding voltage back that way, but very unlikely.
I should have noted, that is with stock bulbs. If you've installed LED's, all bets are off.
There's no reason to replace all the sockets if only one is corroded or loose. I'm not a believer in throwing parts at an issue, I like to find the problem and then correct it. If a socket is needed, or they all look bad, fine: replace them.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If you have any other issues here is a simple schematic to help you figure all the wires out.
