lack of Road Feel after R/P install
Hey guys. I installed a Flaming River R/P in my '79 earlier in the fall and noted that while the steering has improved greatly, my return to center was lacking and there was no road feel to the steering, like the wheels were off the ground. I installed offset upper A arm shafts, (had the slotted before install). I can now achieve 5* Caster and .25* neg camber, wheels tipped in at the top, with maybe 1/6* toe-in. Now my return to center is a little better but not much and still no road feel. Is it possible that the P/s pump is delivering too much pressure to the R/P? Has anyone else had this issue and how did you solve it. or do I just have to get use to it?
Thanks in advance.
Clyde
Thanks in advance.
Clyde
Wonder if something in the rack is binding? With 5 dgr of caster it should absolutely return to center if you let go of the wheel.
The level of assist is not determined by the pump. There are valves inside the rack that set the assist.
what size wheels/tires and what cold air pressure setting?
It feels pretty free with the wheels of the ground and turning from the steering wheel.
Guess those valves inside the R/P are preset.
No mention of other Mods. Are You running the stock PS Pump ? If You have installed a LS based Engine and running a Gen II PS Pump its got to much Flow and makes the Rack feel like a Lincoln Continental. There is a reduced Flow Pump made for this issue. The same rack can be used as a Manual Steering system. Just disconnect the Pump and see how it drives with out.
