Help with broken seat bracket
Hi,
The front foot on the drivers seat bracket broke just about in the center. This must be common as replacement feet are readily available. I ordered and am waiting for a pair now. I removed the seat and it seems the feet are held on with a rivet. Is this correct? I would like to know before chiseling or drilling the item. If it is a rivet does anyone recall the size and type(material).
I don't know of anything else that looks like that. Any info appreciated.
Thanks,
Ray
Thanks,
Ray
You cant use a bolt and nut?
I never had this problem but if it's a big 1/4 rivet like GM uses on their window regulator? Harbor freight sells a massive rivet gun to handle a rivet that size and my local GM dealer had the rivets for my window regulator.
Having gotten the new part, and having drilled out the 1/4" rivet it looks like I can use a thin headed screw and nut . Will have to back up the nut by inserting a screwdriver or ? into the track. Thanks for the input.
Ray
Ray
