soft brake hose replacement issues???
I am trying to replace the rubber brake hoses to the calipers. I have the caliper off but am having trouble getting the soft hose to disconnect from the hard line. What size wrench should I be using?? I am afraid I am starting to round off the nuts and dont want to go too far and regret it.
The c clip came off fine and it was no problem getting the rotor off. any help is appreciated as I am trying to get this done today.
Believe its 3/8 on the hard line. Get a line wrench (or flare wrench). This has a small opening to provide max grip on the fitting. Also use a backup wrench on the soft end if its turning.
i just got to carquest before they closed to pick up a flare wrench (i never heard of one before) Hopefully I can wrap this up tonight or tomorrow am.
1 Post
St. Jude Donor '16-'17,'19
I couldn't get mine loose even with a flare wrench. I used a 10" pipe wrench and it worked like a charm. A 6" would have been better/easier but I couldn't find one locally.
More commonly called line wrenches ......well stocked auto parts stores will have them....Most of the steel lines to calipers are 3/16 ths and if I recall correctly the line wrench size is 7/16
If the nut is starting to round off and the nut is seized...put a pair of Vice Grips around the flare wrench.....use some heat on the connection and spray some PB Blaster/Liquid Wrench or other rust buster on the connection 1st.
Should the c-collar be in place while I attempt to loosen the nut or should I have the c-collar off first?
Alright I temporarily put installed the new caliper and pads to the existing old rubber line(not an easy task). After bleeding both the front sides repeatedly the pedal feels ok and the brake light does not come on any more. However when I test drove the car to see whats up the front caliper that I replaced locks up first on panic braking and in normal braking it pulls to that side noticably. Is this because I have not put the new pads on the opposite side yet and the new pads just grip first or is there some other problem???
Those old rubber hoses deteriorate from the inside. You MUST change all the hoses out to be sure of having a safe system. Use heat, rust penetrant, etc.--whatever you have to do to change it out.
I had one hose doing what your is doing. In the end, I had to cut it off and replace one of my brake lines. Hopefully, yours won't require that fix.
1 Post
https://www.corvetteforum.com/forums...continued.html
My dealings with the rubber line. Read down through about the 5th or 6th post.
i will give the heat a try as i have hit it with enough liquid wrench to loosen every bolt on the car. how difficult is it to replace that brake line from the proportioning valve to the caliper if it comes down to it???
thanks
Master cylinders are easily rebuilt. The rebuild kits come with new seals, a new piston/valve set, and lines/fitting to allow you to bench-bleed it before installing (or once installed but before attaching lines).
If your M/C has not been rebuilt previously, you should do so while you are working on the brake system. If your vacuum booster is working fine, no need to rebuild it.
