Factory Side Exhaust...header compatibility???
I am looking to install factory style side exhaust on my 68. Previous owner had side exhaust on the car however his son had removed the exhaust by the time I purchased it. I am running same heads however when I research which headers to buy there is note that says will not work with angle plug heads. I am running the GM double hump heads with angle plugs. I think many aftermarket heads also have angled plugs. Is anyone running the double hump angle plug heads with stubby headers and side exhaust. Any help is greatly appreciated.
A customers 70 SB has headers and angle plug heads. What a pain it is to change the plugs. Plug wire routing is also a PITA. The car does have sidepipes. I know nothing about brand of headers or sidepipes . but everything fits and works.
IIRC we always have to get the short Accel plugs at tune up time
http://www.amazon.com/Hedman-68280-H...ges/B000RE9IKW
http://www.summitracing.com/int/sear...Hedman%2068280
Headman is what i was looking at when i saw the footnote saing they would not work with angle plug heads. The more I read i think these heads are also called D port heads.
I've been using these for many
years, fit well, no problems. However I do not have angle plug heads.
Looking at these headers, it occurs to me that the mounting flange is what will be in the way of angled plugs. I wouldn't think its all that hard to cut or grind part of that flange off. I do think that the collector will be lower than the stock pipe though and that's already prety low.
The Hedman's, I'd assume, because to the best of my knowledge, Hedman was the only one that made headers that would hook up to the factory side pipes. However, as I'm typing this, the thought of McJacks headers popped into my head. Possibly McJacks makes headers that are side pipe compatible.
