Aftermarket seat belts
Anyone have an opinion or has used these belts?
Do you actually use the shoulder belt part?
http://www.ebay.com/itm/281279739640?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Webbing is tight and doesn't slide in the clip part very well. Once the length was set for me I don't move it, so no big deal.
Also the preload on the spring isnt enough. Its just dangles. It won't retract far enough and sometimes will get stuck in the door.
I sent them the original retractors, clips and other hardware from a parts car that I had. Swapped the red belts for silver. Look great.
Id rate a 7 out of 10 just because the clip doesn't slide on the webbing very well and the retractor needs more "pre-tension". It would be cost prohibitive for me to ship them back for adjustment, so if for any reason I have them out ever again, then, maybe I'll send them.
dodosmike
1st Gear
1972 1973 Corvette C3 Three Point Seat Belt System with Dual Retractors | eBay
