What modifications required to fit Boss 338 wheels on my '75?
I'm looking at getting a set of 18x8 Boss 338 wheels and 250/45/18 tires
I understand that the e-brake bracket needs to be relocated, but are any other modifications required for these wheels/tires to fit?
Car is a mostly stock 1975 Stingray
Received 3,219 Likes
I'm running the same size as Donnie-
I do have offset trailing arms - Vansteel coilovers and small flares on the rear - so I went w/ the bigger rim on the rear
The Boss wheels are LUGCENTRIC- where as the wheels are centered w/ the lugnuts. The OEM (and many aftermarket)are Hubcentric.
I had som rings made up to fit the bigger hub the Boss's had- I'm just not fond of Lugcentric.
Boss hub- 82.80mm Corvette hub- 70.3mm
I had mine machined out of aluminum- but there are some plastic ones for about $25 for the set of 4.
http://us.hubcentric-rings.com/size-82.8-70.3/
Combo spacer & hubcentric adapter-
DSCN4814 by Richard Hayes, on Flickr
I had some rings made up to fit the bigger hub the Boss's had- I'm just not fond of Lugcentric.
The problem turned out to be the wheels being off just a little bit off center bit because I didn't torque the lug nuts enough before putting weight on the wheels. I didn't trust lug nuts alone to keep my wheels centered on the hub after that. I don't know when Corvettes first had hub-centric wheels, but the C3's did and the new Corvettes and most European cars do too.
Something nobody mentioned yet is that the backspacing on BOSS 338's are 1/2" more than stock wheels. That moves the wheels 1/2" more into the wheel wells than stock wheels. That's why Richard and I have hub centric spacers pictured in his reply (the ones laying on black granite).
Here is a picture that shows how the hub-centric adapter ring fits inside BOSS 338 wheels:
The ring part of the hub centric spacers fits the same way but are part of the 3/8" spacer.
The lug holes in the spacer are recessed to allow for extended cone lug nuts like these:
The extended cone lug nuts (from Jegs, Summit, etc.) allow the use of the 3/8" spacers without replacing the stock lug bolts with longer bolts. Our son is a CNC machinist and makes the hub-centric spacers in the picture. I recently sold the last pair I had, but he can make more.
A set of 4 cost 4x the cost of plastic spacers, but they are billet aluminum, not plastic. Send me a PM if you're interested.
MN80vette-
Is your son back to making them?
Richard
Richard
There is another option that are very similar to the Boss wheels and those are the Ridler 695s. The nice difference between Boss (nothing wrong or against the Boss wheels) and Ridler is the offset off the back spacing. The Boss wheels (especially the front 18x8s) get too far sucked into the wheel well and look odd. The Ridler's will have more of a full wheel well because off the offset being more towards the outer dimensions. Set up with 18x8s + 245/45s in front and 18x9.5 + 275/45 in the rear makes for a nice setup. You will need to move the rear E-brake cable mount but the look is well worth the small effort.
Attachment 47889008
Attachment 47889009
Attachment 47889008
Attachment 47889009
Stock C3 wheels have 4" backspace. It's the extra 1/2 inch of backspace that sucks the wheel into the wheel well. Both BOSS and Ridler wheels need spacers to move them further out in the wheel well.
I am assuming the diameter of Ridler hubs are bigger than car hubs (same diameter as BOSS hubs?) so they fit almost any car. If Ridler wheels had the same diameter as C3 Corvette hubs, then Ridler wheels might have too of a hub for some cars. Ridler wheels would still need adapters to get the centering advantage of hub centric wheels.
Attachment 47889008
Attachment 47889009
Attachment 47889008
Attachment 47889009
