Vintage Wheel Works "Vintage 48" wheels DO NOT clear stock calipers
Just wanted to contribute some knowledge on the VWW V48s since I couldn't find it prior to buying these wheels. Hopefully I can save someone else the trouble I'm in.
I ordered a set of the V48s in 16x8. Their web page for the wheels contains this sentence:
"This wheel has 3/4" clearance from the axle plane to the backside of the spokes and will fit over 4-piston Corvette brake calipers."
Unfortunately, the wheels do not clear the front calipers (on a '69). I made the mistake of not verifying their statement prior to having tires mounted, so I got a very unpleasant surprise when they didn't clear.
It's not a huge clearance issue - adding a ~3/16" spacer allows the wheels to fit. But they're clearly advertised inaccurately, so just be aware.
I've contacted Vintage Wheel Works to see what they have to say on the issue - I'll update when they respond.
I have the V48 in 17" size, no issues. I know that doesn't help you. It's a great looking wheel.
Oh, I have Wilwood brakes.
You post in the "wheels" thread was one of a few that made me go with these. I suspect that the Wilwoods must be a hair lower profile than the stockers, which would probably make them clear.
Thanks for the alert. I am aware - in back I'll run 1/2" spacers. In front the look and fit (other than the brakes) is ok, since I went with some wider tires so that the outer edge of the tire is in effectively the same place.
Sorry about the crappy diagram, but you can see that as size a becomes smaller (backspace), size b (mounting flange depth) becomes bigger and thus the spoke clearance becomes greater.
Actually it is. As this is a cast wheel they probably cast one wheel that has an oversize mounting pad that they will machine down to make the different offsets. So on a 16x8 with 0mm offset, the spokes will be closer to the mounting flange. On a 16x8 with -12mm, the spokes will be further away from the mounting flange and therefore a bigger space to the spokes.
Now, if they wanted to make up their mistake by sending me a set of 16x8s with a 4" BS (with a larger pad to clear the calipers) I'd be all over it...
That all makes perfect sense generally, but VWW only make one backspacing/offset in this wheel in a 16x8, and that one model is the one they describe above.
Nick
Hi,
I got caught with exactly the same problem with wheels from US Mags. It seems the "caliper height" you see in the drawing below is not always specified.
Joe
Joe
