78 heater/ac blower motor toasted!
Has anyone had to change out your blower motor? How do you get at the thing? I'm guessing by removing a panel underneath behind the wheel well? Actually the more I look at it, I don't think that's the answer either or at least I hope not. I think maybe I'll have to remove the coolant overflow bottle inorder to get it out from the top?
Not sure if it's the same exactly but on my 77 I had to remove the overflow bottle and my car has a/c so I had to loosen the compressor and rotate it a bit out of the way to get the bottle out. Changing the motor out was very easy after that
Thanks danh77 for the reply. Yes it sounds like they're the same. Once I get the overflow container out of the way it looks like I'll be ok.
DUB
YES...the overflow reservoir has to come out so you can remove the blower motor. Still FUN to get out...I have been there many times. I still get to a few of the fasteners from the bottom. AND...when you get the blower motor out....you can look down into the area where your A/C evaporator core is and see if you have a bunch of ground op leaves blocking the front face of it....It is not perfectly clear view...but it will give you an idea. AND then that is when I use my modified shop vacuum cleaner with hoses that are reduced and run a hose down into this area and with my vacuum cleaner empty...I will vacuum it out and see if I am pulling out any leaves and crud.
DUB
DUB
Here is a photo that my help you locate bolts etc. Its from a non A/C wrecked '78
I think the blower housing for ac and non ac cars were the same, just the heater cores were different. Somebody please confirm or deny.
dodosmike
Thanks for the photo dodosmike. Actually the blower housing is different because that one doesn't have the section that houses the a/c evaporator coil like mine does.
I can say it is FUN changing out an evaporator core with the engine in the car. You have to separate the box on the firewall. I have done it...bit is is a bit of fun. The half with the blower motor stays...and the half closest to the engine is what will come out.
You still can have R-12 used...but it costs more. The current 134a Freon is what is being currently used. You may want to replace the accumulator/drier.
DUB
YES...as long as the evaporator core is GOOD and NOT leaking...it can be re-used.
DUB
DUB
I am by NO MEANS an Air Conditioning expert. I have a guy who does all mine...but I know enough. Yes...different oils and different amounts of freon are used...depending on what freon is in the system.
I hope it charges up fine and does not leak down.
DUB
DUB
Thanks Dub, yes me too!
