Are small block 2.5" factory sidepipes an option
I have been trying to determine correct sidepipe manifold combo for my 68 with 492 angle plug heads. Seems my safest bet is ram horn exhaust. I was thinking about McJacks redesigned ram horns with 2.5" collector. Right when I think I have it figured out I hit another obstacle.
I love the look of factory side exhaust but hate the thought of resticting exhaust flow. My intention was to go with 2.5" manifold collector and 2.5 inch pipes. Does anyone make a 2.5 inch small block pipe for the factory style side exhaust?
https://sweetthundermi.com/side-exha...ifolds_big_blo
Sweet Thunder have a 2.5" factory muffler. Aluminized & SS
any reason you don't want the Hooker style side pipe header exhaust. I have them along with the 492 heads.
[QUOTE=MelWff;1589721963]any reason you don't want the Hooker style side pipe header exhaust. I have them along with the 492
I like the 69 style side pipes. I have known my car since about 1979. My fathers best friend had it and it always had 69 style pipes on it. When he passed his son removed them years later iIpurchased the car and want to bring it back to how I remember it.
I have found the combo that will work. McJacks exhaust manifolds with Sweet Thunder oversized pipes.
2.5 manifold
1962 through 1965 HP small block Corvette had 2.5" exhaust manifolds. You can buy the from Paragon and from other vendors. They should fit the C-3 because the frames, for the most part, are the same for both generations of Corvettes. Make sure the accessory holes are there for your application. Jerry
To answer your title question the answer is "YES"
Recently added N14 side pipes to my '69
Here is what I did ==> Click Here
George
George
