EZ-EFI 1.0 tuning problem
Have you tried asking over at the FAST product support forum?
http://www.cpgnation.com/forum/forum...ort-forum.235/
Hi,
I'm very happy with my EZ-EFI 1.0
But I have one problem that has been having since I bought it back in 2010
My problem is, every time I will make a new tune, and I come to the point "turn the key", then the engine runs for 2 seconds, and then engine stops, and the EZ display "error"
What have I done:
Prime with extra gas before start.
Connect the green wire from the harness to ground, to be sure fuel pressure when starting. (like it says in the instruction)
I have no problem starting the engine after "a new tune", but I have no possibility to have the EZ adjust the throttle blades.
Does anyone else have this problem?
And does anyone have a solution for this problem?
Thx.
What have I done:
Thx.
I've been in contact with Comp Cams Tech support regarding my problem via mail, and there forum.
With no lock, I come to the point that tech support don't reply my mails, because they don't know "what to do" I think. But I will say, that they tried hard to help me, so no hard felling here !!
But my car is running now, what I did was, when I made a new tune, then a second person took a syringe with gas, so as soon a I started the car, then gas came from the syringe for him first 10 sec. or so.
After 5-10 sec. the injectors opened, by them self, and I could finish my tune.
So finally after I installed AFR 195 heads, Comp Cam EFI cam/Hydr roller/1.6 Rocker arms, Edelbrock 8810 water pump, a new set of headers, 3 months ago, my car is driving again
I've only been driving for ½ hour or so, but the car runs strong now, and only with ½ hour "programming"
Thx.
P.S I would like to thanks Matt from Comp Cam for helping me
